Question about Brother 6-In-1 Printer/Fax/Copy/Scanner
Copies Coming out Dark
Whenever I make a copy of something the copies come out with a lot of dark streaks.
  • emunenen Oct 24, 2008
    I have a ricoh ft4618 copies come out too dark i need to know how to clean the rollers
  • 832 Answers
Please give modell number and name. Cant give you a advice out into the blue :-)
Posted on Sep 14, 2007
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Dark streak on copies
Drum, wiper, or fuse rolls. Pull out toner unit see if you can see those lines.on the drum.
Jan 16, 2014 | Xerox XC830 Copy Machine Refurbished
Dark streaks on copies
replace the the drum iff not that the the fuser
Jan 03, 2014 | Konica Minolta Minolta DI1610FP...
All my 8-1/2" x 11" copies are deeply streaked
Chang your UHR and LHR with stripper fingeres, if it is not available at your country change the fusr unit it will resolve your problem feel free to contact me if you have any difficulties and rate me
May 03, 2011 | Sharp Office Equipment & Supplies
Copies too dark
Hi Scottie,
Please clarify if the darkness is like a darkened background or like streaks across the page... If it is the former you will just require a clean of the optics, if the later then a drum cleaning blade will probably do the trick...
Please let me know if I can help further johno@execs.com .
Oct 25, 2009 | Copystar CS-2114 Copier
Machine over heated now the copies are black
Do the copies come out totally black or just dark???? Does the copiers scanning lamp turn "ON" when you go to make a copy? If you smell something burning, you may have paper wrapped around the upper fixing roller...
Apr 28, 2009 | Sharp AL 800 Copier
Copies have black streaks now
Dirt on the narrow glass will cause streaks through the Auto feeder, but copies should be clean if using the main contact glass if that's the case. Dirt/toner anywhere else (ie:laser optics) would cause light areas on the copies- not dark. Did this happen the very first time you used it, or shortly after? In other words, could it be coincidental? It sounds more to me, like the PCU (photoconductor/drum unit) needs replacement, or a fuser roller.
If cleaning the glass doesn't help, then one of these 2 things is causing your problem.
Apr 23, 2009 | Ricoh Aficio 450 Copier
Our Gestetner DSm645 gives Dark Copies..........
Sounds to me like the drum needs replacing, and likely the developer too. There is probably a haze of toner still on the drum. You can check by opening the right side cover and looking at it. Is there toner on the drum (green cylinder). It may not be too obvious depending on how dark the copies are. GENTLY wipe a tissue across it after making several copies - it should be clean if the drum is functioning properly. If it is, it could be the fuser that is wearing out, but I'm leaning toward the drum. As I said, if you need to replace this, it is a good idea to do developer at the same time, because these machines tend to be a little sensitive.
Mar 18, 2009 | Office Equipment & Supplies
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
148 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
