Question about Refrigerators
Maytag refridgerator leaking water down the front
I have a Maytag refridgerator that's about ten years old. It's a french door style with an ice maker and a dispenser on the exterior of the door for ice and water. about a year ago it started leaking water from around the dispensing area but I'm not sure from exactly where (the drip tray seems to fill up most of the time though) water then runs down the front of the fridge and onto the ground. I just shut the water off to temporarily solve the problem but I would like to fix it the right way. If you have any ideas for where to start I would appreciate it.
  • FreeFighter Nov 08, 2007
    My problem is that the water is running and overflowing the ice tray and bin. Looking at the schematics and the wiring diagram, there are two valves on line with the I/M. Either both valves are stuck open or they are both getting voltage to operate them. They were flowing until I went into my crawl space and turned off the water. Where do I access the valves. are they on the back of the unit or inside the freezer?
    Novelist:
  • 87 Answers
It sounds as though you may have a 'dodgey' water solenoid valve which is allowing a constant flow through the valve. When the water enters the cabinet it goes into a double solenoid valve which splits the suply to the ice machine and the water supply. This valve can get limescale build up preventing it from closing properly. This is really the only control you have over the water supply. The solution I would suggest is replacing this valve. However I would suggest getting a professional to do this as you would then get some sort of guarantee on the work carried out. This valve is located on the rear of the cabinet normally on the RHS. Hope this is of some help.
Posted on Sep 11, 2007
Lg French door inside ice maker stops working but water flows out the back of the fridge where the water line gores in. Water line is fine and just had a new ice maker put in but it still does not produce...
Sounds like you have to have a leak in the water line somewhere. The water line goes to the top hinge in the door, so the water has to come from somewhere below that point or it would be collecting inside the door and leak out the front. A leak would prevent water from getting to the ice maker, or a leak at the valve could have this effect as well. Check the water valve that gets a call to send water to the ice maker.
Jul 07, 2014 | LG LFX25960ST Stainless Steel French Door...
Ice maker does not shut off makes ice rill jammed then water goes everywhere
It sounds like you have a malfunctioning ice maker that could lead to future problems. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 08, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice build up on floor of freezer drawer
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
542 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
