Question about Acer AL1914 19" LCD Monitor
Green blocks on screen
If I play some games on my screen is small green blocks like a grid.
Where can the problem be?
Im using a P4dual core 5200 AMD 128bit, 8gig RAM, 8600 GFORCE128 bit 512mb. Using directx 10 and running klm codec pack 4.70
Can you help me?
  • freekshigh Apr 16, 2009
    Im using a P4dual core 5200 AMD 128bit, 8gig RAM, 8600 GFORCE128 bit 512mb. Using directx 10 and running klm codec pack 4.70 I've taken out the video card reinstalled everything then it works fine for 5 or 6 times but then the blocks comes back. Small at first the after a day or to they get bigger
    Can you help me?
    President:
  • 1,902 Answers
Try and update the video card. also make sure that it is installed correctly pull it out and reseat it make sure the power wire is also plugged in
Posted on Apr 13, 2009
The screen turns green after playing videos for 20 minures
The Video Controller works off of the RGB principal. RED/Green/Blue pixels. The mix color is dependent on the formation and density of the pixel and rates. When one or more colors are absent the only functioning color will dominate, and it is Green in your case. The screen liquid crystals in Red and Blue are failing and only a screen replacement will fix the situation.
Jan 04, 2015 | Toshiba C655D-S5200 Amd Dual-Core C-50 3Gb...
I install Burnout paradise the ultimate box and got an error when try to play the game... this machine gpu does not support shader model3 which is required to run this game. I have Intel(R) G33/G31 Express...
you must upgrade your graphic card. the problem as nothing to do with your chipset. This are the minimum requeriments to run the game:
OS: Windows XP/Vista
Processor: Intel Pentium 4 @ 2.8 GHz / AMD Athlon 64 3000+
Memory: 1 Gb
Hard Drive: 4 Gb free
Video Memory: 128 Mb
Video Card: nVidia GeForce 6600 / ATI Radeon X1300
Sound Card: DirectX Compatible
Network: Broadband Internet Connection for Online Multiplayer
DirectX: 9.0c
Keyboard
Mouse
DVD Rom Drive
Recommended System Requirements
Processor: Intel Core 2 DUO @ 2.5 GHz / AMD Athlon 64 X2 5200+
Memory: 2 Gb
Video Memory: 512 Mb
Video Card: nVidia GeForce 8800 / ATI Radeon HD 2900
DirectX: 9.0c
Keyboard
Mouse
DVD Rom Drive
Aug 26, 2012 | Computers & Internet
ANOTHER BROKEN XBOX 360
replace heat pads they are so cheap. wrap pennies in electrical tape and put it on were the heat pads were. use Heat Sink to glue it on
Oct 01, 2009 | Microsoft Video Game Consoles & Games
Video Card Problem
hi. The amd semprom has similar to an intel celeron. These cpu's are not gaming cpu's. The graphics card you are using is now quite old- very few agp graphics cards are made now. I would say that the cpu and gpu may be the problem but it depends what game you are playing. New video cards use pci express slot and new cpu's are dual core and quad core. If you are serious abot games then you could do with a new motherboard- maybe one supporting an intel core 2 duo cpu, to that add at least a Nvidia 9600gt 512mb gddr3 video card and have 3-3 gb's of ram.
May 27, 2009 | ATI RADEON X1650 Graphic Card
AMD Athlon 64 X2 +6000 "system idle process: %50" ???
Hello... It would be helpful if you post which Video card you are using and the Operating system. The below details are assuming that you are using Win XP. Actually you need to understand the system idle process in the inverse meaning. More percent of SIP indicates that there are no running processes capable of utilizing the processor to its max. Theres nothing wrong with your processor and the dual core optimizer you installed is good enough to care of your processor from overheating.
Now the frames in the games you play might be due to a entirely different reason.May be you should decrease the graphic detail like high resolutions and advanced textures. Please play the game at 1024*768 resolution. Turn off Antialiasing,Vertical Sync. Please post the game which you are playing and the graphic card you use. Go thru these threads.
http://forum.osnn.net/showthread.php?t=783&page=3 http://www.devhood.com/messages/message_view-2.aspx?thread_id=30874
Oct 28, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
I got an AMD turion x2 64 processor in my new notebook n after reading reviews comparison to core 2 duo i m really tensed!
You made a good choice. In the CPU arena right now, the difference between the two CPUs is a toss up. The slight advantages of one vs. the other in benchmark tests is nominal and actually artificial..
What happens with an AMD CPU is with the associated GPU onboard. And with a 64bit processor, the number of apps and games that take advantage of 64bit CPUs has always been limited but they are growing. This will only become more and more numerous.
The main architectural difference in the two was in how the two cpus communicated and the AMD was first to use a bus between the two cores and the Intel had to go to the onboard memory controller and back. That was in the first inception. Still, AMD has been far in advance of Intel and Intel has played catch up in tricks inside the cores and how the north and southbridge took advantage of the cores' architecture.
Needless to say, I'm an AMD power user and my gaming rig has an AMD dual core on an Asus/Nvidia board and an Nvidia PCIe 9800 GPU.
In the long run, all modern notebooks require you to own a pad cooler to use these in your lap or not, they all produce heat. So, just get a good one designed for your laptop so it snaps into place and will keep your rig nice and cool.
At a LAN Party you won't suffer from having a dual core AMD cpu, you'll hold your own and it will be an even playing field and the wins will go to the person with the fastest fingers... as it should be.
Sleep easy friend,
Worldvet
Oct 26, 2008 | HP Pavilion DV5234US Notebook Laptop
My pc stops functioning after playing any game for a few minutes
try to use higher video card 128 mb or higher and add more memory/
Mar 09, 2008 | XFX GeForce FX 5200 Graphic Card
Acer AL1914 19" LCD Monitor Logo
317 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
