Question about Polaroid FLM-3734B 37 in. LCD HDTV
Does not turn on
My poloroid LCD tv does not come on. The blue light comes on, indicating that it should be on, but it isn't. After repeated unplugging and plugging it back in again (sometimes for 15 minutes of this) it finally does come on.
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked. We did that for about 2 weeks. Then one day nothing, no matter how long I left it unplugged.
My tv is 18mos. old out of warranty and Polaroid refuses to do anything about. I am extremely upset because I know that this is a manufacturing defect.
This may or may not work for other Polaroid models I have no idea. Here is a picture of my info.
Anyway here is how i fixed my set.
Total parts cost $5.12
This has worked for me, I am no technician so I can't say that it will work for you. Click here for information on caps. Or here
If you try this it is at your own risk!
Defective Parts:2 CapXon 1000uf 10v caps.
Replaced Parts:2 Off brand 1000uf 16v caps. (the closest match my local supplier had.)
Once unplugged and flipped over I removed these three screws to access the control box.
With the cover off I removed 3 more screws and again carefully pryed up on the control box cover to expose the inside.
4f3d408.jpg Circled is the location of the bad caps. (This is an after picture. I didn't take any pictures of the caps still on the board.)
Press your index finger over the tops of the 2 caps and feel for a bulge. Good caps should be sunken in. Bad caps badoes not turn on - b10c4c4.jpg />b10c4c4.jpg&does not turn on - 1822746.jpgare mine removed
1822746.jpg In order to de-solder your caps you must unplug all connectors and remove the 4 screws holding down the board. Be very careful!, and only touch the sides of tdoes not turn on - 1b2e11a.jpgear an anti-static band also.
1b2e11a.jpg Once removed pull of the plastic shield underneath the board. Be careful and save it, YOU MUST PUT IT BACK.
Carefully de-solder the old caps. Replace with new caps.
Note the polarity This is very important! On the board look for the + sign. That is your positive. The longer lead should go here. Take your time and verify This step.
CLICK HERE FOR CAPACITOR POLARITY
(sorry no pics on the cap removal and install I wasn't positive that this would work so I didn't think about taking any.)
Reverse the procedure to put your set back together.
Now plug it up and hope it works for another year! b87cf86.jpg It works again
Posted on Apr 13, 2009
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
Remote control code for poloroid model number TTM 2420 TV
Hello
Four digit universal remote code for Poloroid Tv are:-
0182 0173 0133
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
[edit Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Nov 29, 2010 | Polaroid TTM-2420 TV
I have 2 poloroid 37" (TLU-03711C) lcd tv's both
You seem to have a few possible problems with these TVs. I've fixed a few Polaroids and most seem to have similar problems. First off, you need to give a little bit more info about your problem.
If your TV's blue LED power light comes on, but you get no picture (a completely dark screen), this is likely a problem with your Power board. You can try looking for bad capacitors (bulging from either the top or bottom) or burn marks on the bottom of the board.
If you are tech savvy, you may want to use a multimeter and check voltages on the main transistors, but only do this if you have experience. Alternatively you could order a replacement power supply, but only do this if you are sure the power board is the only problem. ShopJimmy.com has a variety of replacement parts for a reasonable price. You should be able to find your power board for $50-$100.
If you are getting absolutely no LEDs or lights at all when its plugged in, then you might have a blown fuse. The fuse is a small red/orange cylinder. If you had a surge, you could just replace the fuse, but if it happened under normal working conditions, most likely something is causing it and would cause it again, if you replaced the fuse.
Now in addition, your video board may have been damaged by a defective power board. If you experience odd problems like a scrambling screen, freezing, or weird color changes it may indicate a problem with the video board or it may just be the unstable power being supplied from the power board.
There is also a small possibility that one or more of the your backlights are not functioning properly. This is less likely, but still a possibility. In some cases its repairable, but if it requires a replacement of the LCD panel, then it's not worth it.
Anyways, hopefully that gives you some insight in possible problems.
Nov 24, 2010 | Polaroid Televison & Video
My flm-2601 lcd tv blue indicator comes on when you turn the unit on but the tv shuts off after about 5 seconds.
This unit most likely has a bad inverter PCB found on the far left of the set viewing it from the back. Go to www.partstore.com They carry a lot of parts for the Poloroid brand set. Thanks
Nov 02, 2009 | Televison & Video
Problem with Poloroid LCD 32 in. TV
stiv0's Support Profile at FixYa will give you detailed instructions for repairing your set
Jan 15, 2009 | Polaroid FLM-3732 Television
Inoperative LCD TV
Welcome to Fixya! My Name is Travis! I have heard this Problem Before on Another Model. Turns out it was the Power Switch in that case. Yours has the Exact same Symptoms. Get that Checked and let me Know so we can go Further or if that is it.
Jan 02, 2009 | Televison & Video
42" Sony LCD Projection
the manual indicates a six blink is "low B error, no"DD 6V" output from "g" board" the "g" board in a sony is usuall the main power supply board. the center pin of "D1634" is where the +6V comes from, don't short the pins while checking. good luck
Jan 08, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Polaroid FLM-3734B 37 in. LCD HDTV Logo
159 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
