Question about Optoma EP737 - DLP PROJECTOR - 1500 LUMENS *NIC* Multimedia Projector
Lcd proctor image
There's a narrow verticle line sort of flashing down the middle of the screen. The image behind the line is what I'm seeing on my Dell Inspiron 4000, and I don't know if the problem is with the computer or the projector.
  • 115 Answers
Disconnect the computer and then run projector if it still comes then service your projector.
Viren
Posted on Nov 19, 2007
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
We have a 42L G30 and it has a verticle black line right down the middle of the screen. What's happening?
mostly the vertical deflection section of your tv is faulty (vertical output IC)
Dec 03, 2010 | LG 42LC2D 42 in. LCD HDTV
I own a dell inspiron 1501. For the first time today, I noticed a verticle line down the middle of the LCD monitor. What may be causing this? The line is about a hair's width in thickness. I specially see...
ok well i have seen more than enough of theese and the result to fix this is that you will need a replacement. Now how that would have happened is by having somthing push down on that and it caused it to have that line, try not setting things on or having things put pressure against the bezzel(hard plastic casing around the screen) causing the line to appear.
Jan 08, 2010 | Toshiba Satellite P30 P35 Series Notebook
The tv has a 3" white verticle white line down the middle
Sounds like your LCD panel is failinf and will need to be replaced it is going to be costly around 1500
Nov 29, 2009 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
I have verticle lines on my Mitsubishi LT-52133. the lines are perfectly up and down and the picture in the middle is good but about 4 inches on the left is dark and miscolored and 4 inches on the left are...
That is not good, it can be as bad the LCD panel is bad which is more likely or the LCD panel inteface board betwwen the screen panel circuit and the main video processor board.
Nov 03, 2009 | Mitsubishi LT-52133 52 in. LCD HDTV
Verticle line running down the screen.Thin verticle line running down the screen.
You have a defective LCD panel. The only way to fix it is to replace the whole LCD panel. It is the most expensive part in the TV (usually $500-2500) depending the make, model, and size. It is also time consuming as you need to take the whole TV apart in order to replace that part.
Oct 09, 2009 | LG Televison & Video
I have a 2 year old Toshiba 32
Your panel is defective.Not worth repair.Try calling Toshiba customer support and see if they will help you.
Sep 28, 2009 | Toshiba Televison & Video
Screen off center
try updating the latest driver for your video and bios. try connecting your laptop to external monitor
if both of this didnt solve your problem, i suspected you lcd screen is faulty and need to replace.
May 29, 2009 | NEC MultiSync XE21 (White) 21 in.CRT...
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
143 people viewed this question
Top Optoma Office Equipment & Supplies Experts
Computer Links
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
