Question about Sport & Outdoor - Others
My water pump works when u test it on battery but will not work when u turn taps on it does not seem as though there is no power between fuse box and pump fuses r ok not sure what to do next
    Champion:
  • 225 Answers
Go back to the water pump and test for voltage if no voltage trace wiring back to fuses sounds like broken wire.
Posted on Jun 07, 2009
Is there 12 volt I can tap into to fit alarm
12 volt taps are everywhere. One of the easiest places to tap off 12 volts is in the electrical fuse box. Whichever fuse you decide to use, make sure it is a non-critical fuse like the ECM or fuel pump. When you look at the fuse panel, test which side of the fuse has voltage when the vehicle is turned OFF. You don't want an alarm system that only works when the vehicle is turned on!
Nov 28, 2017 | Cars & Trucks
I have a Biasi Riva Advance HE Combi Boiler. The pilot light and fan dont seem to be working, I can hear a click when I run the hot water tap and a click after I turn tap off,
Have you bleed the air from system and run hot water and heating at the same time , bleed the pump . you could have air in the pilot after turning it off
May 01, 2017 | Water Heaters
Whole fuel system
The main fuel pump in a Volvo is really well built and rarely fails (Bosch simply makes great fuel pumps). A good survival trick if you think a main fuel pump might be bad... give it a quick tap with a wrench. For best results, if possible, tap the pump when cranking the engine (while power is going to the pump). If the pump is bad, often the tap will make it come to life and it may stay running until you shut it off. This trick can get you back on the road and get you home in an emergency. If it's a bad fuel pump relay, this will NOT work as there will be no power going to your pump. If this is the case, you might try the below relay bypass "jump" trick to get power going to the pump. TESTING YOUR FUEL PUMP
How to "JUMP" the fuel pump circuit at your Volvo 240 fuse panel:The fastest method to make the main fuel pump run (bypassing the Fuel Pump Relay) is by jumping two circuits at the fuse panel (left side driver's kick panel).
You can make a jumper from a wire with stripped ends or even a straightened paperclip. Jump the circuits on the right side of the fuses for best results
For a 1979-84 240, jump fuse circuit #5 to #7.
For a 1985-93 240, jump fuse circuit #4 to #6.
If the main fuel pump doesn't begin running when jumped (you should definitely hear it humming), you either have a faulty fuel pump or faulty wiring to the pump (bad wiring is really common under an old 240, near the pump). This test of course assumes your battery is good.
If one of the fuses blows during this test, the pump circuit wiring is shorting to ground somewhere between the fuse panel and the pump.
thx
Jan 18, 2012 | 1984 Volvo 240 Series
Windscreen washer does not work on renault megane coupe sports motor works but no fluid comes out do not want to take washer bottle out any ideas please
i Just fixed a problem with a renault megan washer motor. If the motor makes a noise but is not pumping any water & the jets@ the windscreen are clear, then pull the suqirter motor out off the washer bottle( the bottle stays in place ) it just pulls out from underneith the bottom stone tray& may need to remove bottom bolt, inner lower wheeel arch. Right Now where the black & white squirter come out of the motor gentlywith a screw driver pop these off together. ( test motor again) ( put in water ) Then with Snap ring plires & part the white & black outlets apart & you will find a rubber seal that looks like it must of grown. When it grows it blocks both ports off. you need to shorten the rubber & keep it flat as remember its job seems to block off either the front or rear port. if it not a good finish you may get water coming out of the front & the rear ifeg your working the front squirters
Dec 04, 2009 | 1986 Renault Sport
Caravan water pump not working changed pump, fuses seem ok still not working
The water pump is usually started by either
1. a drop in pressure when a tap is opened, and an in-line pressure switch turns the pup on
or
2. a microswitch on every tap.
which ever system your caravan has, it will be one of those thats not kicking in the pump.
Aug 27, 2009 | Kitchen Appliances - Others
Clicking noise coming from relays in fuse box
Have you noticed any water or other signs of a leaking windshield under the dash. It sounds like you have a GEM module problem, it bolts to the back of the fuse/relay box. If it is from water damage you will need to replace the fuse box aswell as the GEM (generic electronic module) don't forget to reseal the windshield.
Jul 15, 2009 | 2002 Ford F150 Regular Cab
1994 Toyota Tercel Starter Problems
sounds to me that you have an igniton problem not a starter problem and or if you have or had an alarm system could be cause if u do give me feedback and i will explain but seems that your starter is fine from what u say but if you think in terms of the elemts to start a vehicle batery gives pwoer to ignition which sends to starter which gives spark etc i would check you ignition system something is causeing a short and not alowing starter to function
Feb 10, 2009 | 1995 Toyota Tercel
Sport & Outdoor - Others Logo
124 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
