Question about LG LRSC21934 Side by Side Refrigerator
Ge refrigerator not cold enough
Our 2 yr old refrigerator does not get cold enough and there is a lot of condensation in the refrigerated compartment.
  • 5 more comments
  • Anonymous Dec 08, 2007
    2 year old GE side by side Refrig. is not cold enough even set at the highest(9). The food in the freezer does not freeze completely..only about 20%. It was making raoring noises a month or so ago and lasted many weeks.
  • pank12 Jan 12, 2009
    my refrigerator will not get cold!
  • cobbblondie Feb 03, 2009
    dididsaythat
    GE S.S. side by side refrig
    36” wide, 31 ½ D and 69 H. Model # DSS25KSRB SS
    ....this is the info she sent me...can't find on the web..I have seen lots of comments on various used refrig...looking to buy off craig's list...to move into house...any chance these numbers & mod# are good..and you can tell me about the fridge...
    Thanks,
    Steve
    srm1@pge.com
  • Anonymous Mar 09, 2009
    Mine has been making what sounds like a fan motor surging and moaning.Has been doing this for months now.In the freezer.I have read that it is the control board # W5RRX10552.That it needs replaced.I have model # DSS25KSRB SS. Side by side stainless steel.It seems to freeze foods ok.Wanted to see if anyone had had the same troubles?
  • joepim_25 Mar 28, 2009
    My fridge sounds like it is working fine when it is plugged into the wall. Unfortunately the the fridge never gets cold!!! What is wrong?
  • Anonymous Mar 16, 2014
    refrigerator not getting cold enough
  • Anonymous Mar 20, 2014
    n not cooling enough
  • 291 Answers
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Posted on Sep 12, 2007
    Guru:
  • 1,524 Answers
1. Is condenser clean ?
2. Is there enough space around the unit ?
3. Controls set for mid position ?
4. Plugged into a dedicated outlet (recommended 12/3 wire 20 amp breaker)
5. Bottom under crispers you will see the drain. Pour a mixture of warm water and baking soda.
Posted on Apr 23, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
2 yr old refrigerator part won't get cold
check the damper vent door between the freezer and refrigerator compartments to see if its frozen or stuck shut so cold air cant pass
Aug 02, 2011 | Kenmore Side by Side Refrigerator
My 5 yr GE GSS22JE is not getting cold what seems to be the problem?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 15, 2011 | GE GSS22JET
I'm not sure which one I have, but purchased my approx. 2 yr. old Kenmore bottom freezer refrigerator from a trusted contractor doing some work in my home. I have a problem with the left produce bin......
Cold air from freezer blows into refrigerator compartment right behind that tray. Freezes stuff in that tray. Pizpoor design. Known issue. With GE refrigerators also of same design. That kenmore most likely was build by GE. GE/Kenmore deny the issue but thousands of posts online about it. No solution. Sorry. Good luck.
May 19, 2017 | Kenmore 62832 / 62834 / 62839 Bottom...
6 yr old built in GE Monogram side by side frig all of a sudden water is dripping from above where motor is and it is really hot up where the motor is
heatman101
Nov 17, 2010 | GE Refrigerators
Refrigerator and freezer won't keep things cold enough. reezer, cold but won't keep things frozen. Already vacuumed fins and cleaned out compressor compartment.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 10, 2010 | GE Refrigerators
GE Profile Refrigerator freezer not working right & ice in refrig
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator doesnt get cold enough
If you remove the back panel on the inside of the cabinet then you would be able to check the evaporator coil (cold bit) and see if it is frozen up. If it is then defrost the system and see if you have any improvement. All the things you have pointed out over the compressor is normal, they do run incredibly hot. If you have got the freezer on a very cold setting I would suggest bringing both setpoints to a mid range setting. Check the temp in the fridge by measuring liquid temp as air temp is prone to fluctuate more. If you still have a concern I would suggest contacting a fridge guy to assist you. Hope this is of some if not limited help.
Sep 11, 2007 | GE Â 17.9 Cu. Ft. Top-Freezer...
Ge side by side not cooling enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Sep 07, 2007 | GE Profile PSS26NGS Side by Side...
LG LRSC21934 Side by Side Refrigerator Logo
2,417 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Mike
Mike
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
