Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do I take off Whirlpool Washer cabinet to get to the pump
Whirlpool Ultimate care II
  • 718 Answers
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
click on your model number. The new window will give diagrams in the left-hand side.
Click on the diagrams. This will show the assembly of the unit. Use this as a guide for dis-assembly and re-assembly and do not mix-up parts as they are removed.
Posted on Apr 13, 2009
5 Suggested Answers
SOURCE:
scottowa
  • 87 Answers
SOURCE: how to remove back & top of a whirlpool ultimate care II washer
I'm not sure of the model number of the stove but usually slide a putty knife under the control panel between the bottom of the control and the top of the base. There is a clip on each side then the panel will tilt back and you can take it off. After that there are 2 gold clips that hold the back on to the base. Remove them by snapping then out of the base. The the whole thing is loose and the base (where the lid and sides are. Comes out as 1 big piece. If you get the model number from under the lid, you can go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
and it will show you a breakdown of the machine. Let me know if you need anything else.
Posted on Mar 29, 2009
  • 641 Answers
SOURCE: Whirlpool washer pump inlet filter
No, there is no filter before the pump inlet.
Posted on Sep 07, 2007
  • 530 Answers
SOURCE: Whirlpool Ultimate Care II LSQ9549L - leaking water
about $60.00 depending where you live
Posted on Jan 04, 2009
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My WHIRLPOOL ultimaTE II WASHER IT FILLED WITH WATER BUT DIDNT SIN OUT IT WORKS ON ANY RINSE CYCLE BUT NO SOUND OR ANYTHING ON SPIN CYCLE
    Sounds like a clogged pump or outlet hose. They're pretty easy to check/replace, but you will spill a lot of water if you don't have a locking hose clamp. The cabinet comes off from the front, (after loosening the control panel, unplugging the lid switch, and popping the spring clips behind the panel), so you should have a good amount of room to set the cabinet aside, but you'll then have easy access to the workings, with the pump and outlet hoses right in front.
    Oct 11, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool ultra care ll, how to replace rubber coupling?
    Flip control panel up, take off cabinet, remove pump off motor, remove motor, and your coupling is on the motor and gear case .
    Dec 30, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
    Hi.
    With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
    Here parts and diagrams.
    Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II - making funny noise
    this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
    Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool washer began leaking. what should i check for?
    check the water pump. you will need to remove the cabinet to see. once you can get the cabinet off, it is usually easy to replace the pump.
    May 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool ultimate 2 model#lsw9750pw3 ser.ct1941128 leaking in front. appears to leak from a bow with 2 hose connected.
    Your water pump is attached to the motor and is probably the source of your water leak.
    Replace the pump.
    Use the attached video to show how to access the cabinet and pump.
    May 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care 2 leak after wash cycle
    Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
    Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II still won't drain
    More than likely you have another garment in the pump or connecting drain line.
    Check it all again.
    Nov 10, 2008 | Whirlpool Ultimate Care II GSQ9669L Top...
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    614 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
