Question about Westinghouse LTV-37w2 HDTV
Wesitinghouse 37" all of a sudden wont work with hdmi cables plugged in. only picture with component cables in. ps3 wont work individually either currently have it directly into cable source and everything is good except the picture is only regular cable feed not hd.
    Problem Solver:
  • 11 Answers
Same problem I had... My problem was with any HD input from PS3 (only HD device I have), the PS3 was fine on other televisions so I determined that it must be a problem with the TV in question. I fixed this problem by unplugging the TV, letting it sit for about a minute and then plugging back in.
Posted on May 08, 2009
I'm having a similar problem. I have my PS3, cable box, and an HD-DVD player going through an HDMI switch. None of the three work, through the switch or individually through the TV. However, all three are hooked up to my receiver with the optical cable, and the sound works fine. I've had this problem a couple of times the last few days. I just unplug the TV and let it set for a bit. I think I'll give the extended warranty I bought through Best Buy a try, though.
Posted on Sep 28, 2009
How to play PS3 in HD on the sharp 37GAM considering there is no HDMI cable. I'm really disappointed in that they didn't make an HDMI input.
What you can try is to use a component lead from the ps3 to the sharp 37 it is a 5 RCA plug lead 3 video 2 audio
Dec 29, 2016 | Sharp Televison & Video
No PS3 signal on TV using HMDI or Component Parts
It could be that either HDMI port could be bad or you might want to try a different hdmi cable. The cable could be bad.
Jun 24, 2012 | Sony Playstation 3 (PS3) Console
Tried to hook up ps3 to a different, older tv. was hooked up with hdmi cable and optical audio cable. bought a component cable that works with the ps3. I can't get a picture or sound. or anything else. ...
HDMI is a digital signal, so your TV and your PS3 are basically talking to each other over the connection at all times. That's why when you plug an HDMI connection into your PS3, it can detect the connection and try to switch right to it. Component cables don't work the same way, they only output information, so it's a one way street. Your PS3 is still outputting information, but it still thinks it needs to output to the HDMI port. The fix is pretty simple, and there are two options.
The Long Way
  1. Plug your PS3 into an HDMI TV.
  2. Change the Audio settings first, so your console outputs audio to a Component source.
  3. Now change the Video settings last, so the PS3 is outputting to a Component source as well.
  4. Your screen should go blank once you do this. Hit the X button once, wait a moment, then use the power button on the front of the PS3 and turn it off.
Now just plug the PS3 into the other old TV with the Component cables, and turn it on. You should have picture and sound now.
The Short Way
  1. Leave the PS3 plugged into the old TV, and turn it off with the front power button. Once the light has turned Red, hold the power button down for at least 5 seconds. Don't let go until you should hear the system beep twice.
Now you should be able to use your PS3 on the older TV without a problem.
The Short Way is a simple reset of your video card, it causes the PS3 to revert to outputting to it's out-of-box settings. If neither of these ways worked, check here at the Sony website, and one of those solutions may better fit you, but it sounds like one of the two solutions above should solve it.
Please leave a comment or rating letting me know if this solved your problem, constructive feedback is always welcome. Good luck with your console and good luck with your games.
Dec 29, 2010 | Sony Playstation 3 (PS3) Console
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
So i have had a ps3 for about 2 years now and the hdmi chord worked fine for 1 year and then all of a sudden i started lossing signal from the tv. If i wiggle the hdmi chord the picture will sometimes come...
Hi friend, see since your regular (component/composite) chord worked well so the problem is with your HDMI chord. It is losing connection with some internal wire try to use another HDMI cable if it still not works so problem may be with your HDMI port.
Composite/component cable works fine but the cost of graphics..... but still HDMI graphics are just too good...
Hope it will work for you.
Jul 09, 2009 | Video Game Consoles & Games
Ive had my PS3 hooked up using HDMI for years now but i bought a component cable because i have just bought a PVR and it can only record using component and not HDMI. The problem im getting is that when i...
Hook it up with the component cable and then hold the power button on the console until something comes up on screen. Make sure you have selected the component input on your tv or else you wont get anything anyway.
What holding the power button does is it resets the video settings to the lowest common denominator and then you can reconfigure it for the optimal picture quality of the component cables.
If that doesn't work double check the component connections on the back of the TV and just make sure they are where they should be and that no accidents were made while hooking it up.
Please post the results from these steps here so that I know what happened.
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
HDMI Port
you will have to look at the manual, but sometimes Audio isn't transmitted on HDMI cable,( I know it makes no sense). sometimes you will have to also use the digital optical audio cable, or SPDIF coax didital cable. I had to use the Di
As for your PS3 I had simillar issue, the PS3 doesn't Automattically adjust from analog, to component, to HDMI. If you get a signal thru the Reg RCA plugs, if you plug in the HDMI cable at the same time, then go to the system settings and change the type of plug you want to use, choose the HDMI, and the screen should flicker then show the signal from the HDMI, then just power off and/or unplug the analog cables, and you are using HDMI. hope this helps, if so thanks for the ratings
Mar 31, 2009 | iLO 3200 32 in. LCD Television
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Dec 10, 2007 | Sony Playstation 3 (PS3) Console
Westinghouse LTV-37w2 HDTV Logo
369 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
