Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
No Audio Out to Stereo Reciever
No sound to stereo through TV audio out.I did notice that if I turn up the volume on the TV I get some volume through the surround speakers however if I mute the TV there is no surround speaker sound again. Havent used this feature since having the set two years. I did just accidently hook up the TV audio out to the reciever pre-amp out and vcr out before noticing the TV audio input jacks. Could I have fried something in the TV? Thanks for any help.
    Genius:
  • 1,153 Answers
First have you went in menu and check audio to see if you are on the variable audio or external output? Check to see if this makes a different with audio jack hookedup correctly of course!
Posted on Sep 11, 2007
I have a Harmon Kardon HK 3370 Stereo Receiver and a Samsung LCD LE40C530F1W. When I connect the stereo Aux jack to the LCD Audio jacks ( red and white rf cables ) I get no sound out via the receiver.
Obviously make sure your stereo mode selector is set to AUX and the volume on the stereo is turned up at least a little when you test it.
If you still have no luck then try increasing the volume on the TV as well. You may have it set so that the level of the audio signal leaving the rear output connectors on the TV varies with the TV volume. That way if your TV volume was turned down or muted when you tested it, then you would not hear anything coming through your stereo.
There should be a setting in the AUDIO OPTIONS menu of your TV where you can switch between a VARIABLE AUDIO OUTPUT and a FIXED AUDIO OUTPUT level.
With the FIXED audio output level, you control the volume of the TV audio coming through the stereo speakers with the stereo remote only.
Otherwise it should work.
Good luck.
Jul 16, 2011 | Harman Kardon HK 3370 Receiver
Can not get sound from tv to play through sterio reciever
One simple way to accomplish this is to run RCA audio cables from the red and white (left and right) AUDIO OUT jacks on the back of your TV, and plug those into the red and white (left and right) AUX INPUT connectors on the back of your stereo.
Then just select AUX on the input mode selector of your stereo and you will hear the TV audio through the stereo speakers.
Make sure your TV volume is turned up about halfway way and then adjust the volume on the stereo to your liking.
In the AUDIO OPTIONS of your TV menu you can usually select whether you want the TV speaker to be OFF or ON. That way you can just control the stereo volume with your stereo remote to hear the TV audio.
Or you can select VARIABLE OUTPUT LEVEL for the rear audio output connectors on the TV, and then you can control the volume with the TV remote and just leave the stereo volume set at one volume all the time.
There are many other ways to hook up sound through your stereo, that is just one cheap and simple one.
Please comment back here to this page if you have any details to add, have any questions, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 30, 2011 | Televison & Video
How do I connect a Sony KDL55EX620 HD TV to a stereo receiver. I am using the HDMI cable from a DirectTV receiver. How do I get the audio to my stereo?
the audio comes out of the Direct TV reciever, OR Audio OUT on the television. Some TVs that take the signal HDMI, do not put sound back out, and in that case, sound signal must come from the reciever box.
Each component, like DVD of Blu Ray will need to have a signal wired to the stereo unit.
Apr 27, 2011 | Sony KDL55EX500 55 in. HD-Ready TV
How connect toshiba tv to samsung home cinema whit hdmi? i connect but still no sound. i want watch tv but listen in cinema sistem
the hdmi jack on the tv is an INPUT jack, not an output. to use your reciever for tv sound, you have to find the audio output on the tv (most do not have an audio out, but some higher end tv's have a fiber-optic digital out, which may or may not be compatible with your surround sound reciever)
if your tv does not have an audio out, the only way to get the tv sound into the styereo is to use a tuner box, like a cable box or satelite box. tuner boxes always have either hdmi or stereo audio outputs.
to use hdmi with your surround sound, you are supposed to run HDMI OUTPUT from the tuner box or disk player into the HDMI INPUT of the stereo, and then run the HDMI OUTPUT of the stereo into the HDMI INPUT of the tv.
Mar 12, 2011 | Audio Players & Recorders
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
NOU SOUND
well I have a work around and a solution possibly. first go threw your menu audio and verify external speakers are not turned off. if there is no setting or it is turned on already try a different video/audio input if nothing else if you have good picture you can use a stereo reciever to play the sound you do not have to input audio into the tv if you have surround sound go straight from your device(dvd, vcr,cable box etc.) to your sereo reciever just the audio plugs (red and white, not yellow unless you have a monitor out from your stereo in which you conect all three to the stereo input then one cable from the monitor out on the stereo to the tv in put
Apr 14, 2009 | Televison & Video
Getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Mar 09, 2009 | Televison & Video
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
Audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Oct 04, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
293 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
