Question about Sony Cyber-shot DSC-W70 Digital Camera
ACCESS?!?!?! My camera keeps coming up with this access error message! the screen goes blue and then access comes up. it flashes continuously. it then comes up with images ive previously deleted!?! ive purchased a new memory stick and this has not corrected the problem. have i pressed some crazy combo of buttons or something?
  • 7 more comments
  • KathyDave Nov 18, 2007
    Same problem - as soon as I turn it on the Access comes on and it beeps - the lens also won't retract all the way. I can view old pictures - but that is about it.
    Any clues how to fix this - or if it is fixable would be very helpful.
    Thanks,
    Kahthy
  • phoenix001 Mar 28, 2008
    Actually it is my sons' W70. From day one (approx 2 years ago) the mode dial settings would jump all over the place, then behave themselves for a while. Just 2 weeks ago the ACCESS error message appeared when turning on the camera and the lens operation was eratic (to say the least). Tapping the lens gently appeared to have no effect, so I "fiddled" more forcibly (if that's a word) with the lens with my fingers when the lens was extended. And guess what! The camera now works like a charm (touch wood) and even the mode dial is behaving itself.
    In hindsight, I do know my son carries the camera in his pocket, and not in any sort of case, so I am assuming grit had entered the lens mech.
  • Anonymous Apr 13, 2008
    my camera keeps comming up with an access message and would not do anything else
  • xmail Sep 08, 2008
    Same 'ACCESS' problem. Turn on the power ..... "Access" on screen ... zoom action erratic ... 30 seconds pass and "Turn the power off and on again" appears along with 'beeping' sound. If I follow instruction, exactly the same thing happens.
    I've tried the 'tapping on lens' the gentle manipulation of lens with fingers solutions offered, to no avail. The camera is not even 2 years old. This puts me off the whole brand! Has anyone tried to solve this issue from the inside? I'm considering having a go - I've got nothing to lose, the fix cost is prohibitive £114.56 and I may as well save and get a new camera - other than Sony of course. Any advice/guidance much appreciated
  • amy6196 Dec 10, 2008
    I have the same problem and have written to sony twice to see what they can do as its going to be £150 to get fixed!!  Which is the same price as the camera almost!! However they were very unhelpful and said its not a fault with the make and no one else seems to have reported any problems??
  • Anonymous Dec 21, 2008
    I think a class action lawsuit is required. NEVER DROPPED MY CAMERA. This is ridiculus.
  • kakyka08 Jan 21, 2009
    Thanks,
    Martha
  • Anonymous Jan 29, 2009
    I have the same problem,access message comes up on the screen,and then...the message -turn off and on again.
  • sujitha May 11, 2010
    i too had the same "access" problem...was just browing and read about "Tapping the lens"....i just kept my fingers covering lens...on clicked on power on...it worked for me...duno if coincidently it work..anyways i am happy that my problem got solved...n my camera is working...thank u.
I had to tap the entire front of the lense on the fat part of my palm. I had to do it 4 times semi-hard. Then the camera just popped on. Thanks for the tip, I did have to do it three times turning it off and on after each 4 strikes. The fifth time was a charm. I now have to do it every time to make my camera work. Crazy but it works.
Posted on Jun 09, 2009
Yeah i had the same problem with my DSC W70. It is because the lense is not alligned properly. When the lens begins to go in tap it a few times on a soft gentle surface to get it realigned. It worked for me!
Posted on Nov 26, 2007
I had this problem.
i first tried replacing the battery, to no avail. The problem with my computer was the memory stick.
Try removing the memory stick and then turning on the camera.
Move all files / pictures on the stick to your computer.
Then format the stick in your computer.
Return the stick to the camera.
Try turning it on.
Format the stick AGAIN inside the camera now.
That should solve the Access problem!
Posted on May 14, 2009
  • 45 Answers
I contacted Sony support about this. They said this problem comes exclusively from dropping the camera (even though i have never dropped mine), so the repair wouldnt be covered by warranty, but they did admit this is a widespread problem. They expected me to send it in for repair and that fixing it could cost up to $100 dollars to replace the lens gears that are faulty/misaligned.
Tapping the lens doesn't work for me. Good luck.
Posted on Apr 11, 2008
Solution #9 (pulling out the lense) worked for me. Thank you so much! :)
Posted on Mar 27, 2010
Tapping it gently didn't work. Neither did smacking the lens casing with the palm of my hand. However, when my husband got out a metal spoon and rapped it several times quite sharply it worked. Don't know for how long, but at this point I've turned it off and on several times and the picture screen seems to be working.
Posted on Feb 21, 2010
Thanks. Tapping worked for me on a Sony DSC-W35. Anyway this is a bad quality problem for Sony.
Posted on Feb 12, 2010
After reading the other post I simply pushed and pulled on the lens a few times and the camera started working. Just like my dad told me when I was kid, if all else fails, hit it with a hammer.
Posted on Oct 17, 2009
Solution #4 worked for me! I removed the memory stick. Cleared it on my computer. Reinserted the stick into the camera and then it worked!
Posted on Jul 06, 2009
If tapping does not work, try pulling it out. we heard a grinding noise then it worked.
Posted on Oct 12, 2008
OMG! at first i saw these answers to the problem and thot none of them would work, until i saw the one that said "pull on the lense" and IT WORKED!!! :D im so happyy!!! i pulled and pushed a little and a miracle happened. finally the camera turned on! thank you SOLUTION #9!!!!!!!!!!!!!
Posted on Jun 22, 2010
I tapped! It worked! Unbelievable! Who'd a thunk it!
Thanks to all for the helpful info.
Posted on Jun 01, 2010
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
Blue screen access error when viewing or taking pics or vids
Please try to take as many pictures from memory stick as you can then format memory stick through format option in setup.
Hope this will resolve this blue access issue.
You can use another memory stick like 1GB in this camera.
Mar 13, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
JVC GZ-MG37U Menu screen won't come on, blue access lt. stays on
you have to check the firewire securety port....
it protect the camera from the wrong conections with the pc...
it doesn"t complot the camera work....
if you have a playback recorder deck it can wait ....
Jan 21, 2009 | Video Cameras
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Your camera has problem in Lens mechanism. If Lens doesn't open properly, camera will not show picture at all. There would be Loading Motor section demaged in Lens mechanism and it needs to be replaced to work camera OK.
Now come to blue screen in playback mode, This model doesn't have internal memory, so you need memory stick/ card to see previously taken pictures.
Jun 21, 2008 | Cameras
Sony cybershot DSC W50
when I turn the power on screen is blue with "access" message. after a few minutes, message is replaced with "turn power on and off". I have removed and recharged battery but keep getting the same message and other functions of the camera will not work.
Apr 30, 2008 | Sony Cybershot S650 Digital Camera
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
FILE ERROR while viewing
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Dec 27, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Nano plus 1Gb
there is a way to reset the device, do a search on google and it should fix your problem.
Nov 18, 2007 | Creative Labs Zen Nano Plus MP3 Player
Sony cybershot dcs w55
Go to Sony support site and check out what error C:13:01 means Then let us know
Sep 22, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
1,818 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
