Question about HP Compaq Presario V2000 Notebook
Laptop not used for 2 months. now not switching on. power adapter checked and found Okey
MY laptop was kept ideal for about 2 months .now it is not switching on power adapter is OK SUJAY
    President:
  • 2,004 Answers
Please plug to power and charge for 12 hours before switching on again.
That fixes it.
rate this fixya
Posted on Apr 13, 2009
My p2 PC was kept ideal for 1 month. Found a (4 pin on both side) loose cable. In on state HDD light glows, fans are not working ,no signal is received. Pl suggest What could be the solution. M S B
P2 as in 'Pentium 2'? If it is, it is too old, save the hard drive and throw it away.
If you have power, which you have as you have a red light, it sounds as if the motherboard has failed.
Sep 26, 2015 | Computers & Internet
How to fix a toshiba labtop that has a crack and wont turn on ?
please check first you power supply by confirming the following
  • do you have power in were you arw working
  • confirmif you laptop power plug or adapter is working
  • if the above is okey open your pc and replace the power suplly
Jul 06, 2014 | Toshiba Satellite Computers & Internet
WILL NOT TURN ON
check your outlet of your power and check your cable if they are okey..sometimes some of the cables has a problem on it. If you have a spare cables ..try it first.
Sep 17, 2011 | Compaq Presario V3500 Series Laptop...
My dell inspiron 1720 laptop has no power at all,,battery are okey and the charger are okey to..
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 28, 2011 | Computers & Internet
Hi Purchased a new 6cell Li-ion Battery for Toshiba laptop .It is giving backup of 2hrs30min .I kept battery with laptop for 3 months and again i started the laptop not charging .it is charging for some...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 08, 2010 | Toshiba Satellite A135-S2276 Notebook
Power problem
first dint buy (not original) adapters and replace the original adapter try to charg battery
Jun 22, 2010 | HP Compaq Motherboard
Camera could not switched ON. Batteries were replaced, Camera was kept ideal 2 month.
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 10, 2009 | Canon PowerShot A530 Digital Camera
Laptop not switching ON.
Battery may need recharging fully after 14 hours or needs replacing.
Apr 16, 2009 | HP Compaq Presario V2000 Notebook
Laptop shuts down when moved around. I have a Toshiba A135-S4467 and yesterday when I went to pick it up and set it on my lap it shut down leaving the power button flashing orange. when I pressed the...
Sounds like a Battery - AC Adapter problem. Do you have an Icon showing your battery level?
Do you have Windows XP? I'm guessing you do because of the memory upgrade.
If you have XP, go to Control Panel - Power Options and check you battery. Choose to show in task bar.
If you have a AC Adapter, the BIOS on your laptop will NOT charge the battery, but it will show that you are on AC (unless it's completely dead)
I'm guessing that if you only had 1g of memory, you have a pretty old laptop, and you probably should purchase a new AC Adapter, and a new Battery.
Apr 09, 2009 | Toshiba Satellite 1805-S274 Notebook
Wireless not working after standby, restart of machine required.
Kaspersky Internet has a firewall built-in you have to turn it off...
Jan 01, 2008 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
HP Compaq Presario V2000 Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
