Question about Refrigerators
Purpose of orange switch in fridge
I have a phillips whirlpool fridge freezer ARG 917. Please tell me the purpose of the orange switch in th fridge. Thanks
57 varieties
  • 1653 Answers
SOURCE: I just bought second hand Whirlpool fridge
I assume that you are in the UK (as indicated by your product number) so call Whirlpool Service on 0844 815 8989 and give them the mnodel no and the 12 digit number that begins with 85 and they will assist you.
If you are not in the UK then go to
http://www.whirlpool.com/custserv/global_sites.jsp
and select your region / country and locate the contact suppoprt tab and contact them with the same details.
Posted on Sep 11, 2009
22yooper
  • 828 Answers
SOURCE: orange star button inside fridge
There is a defrost timer that starts the defrost. It may be in the section where the temperature controls are located. You will find a round hold with a clutch head screw accessible through the hole. Turn the screw clockwise SLOWLY until you hear one audible click. The system should then be in the defrost mode. Wait about 25 minutes and if the timer is good the system should go back into the cooling mode. If it does NOT, advance the timer to the next click and get a replacement timer. The defrost should have taken place if there is no other problem. If the unit went back into the cooling mode and defrost did not take place your problem is in the freezer section behind the rear wall. There you will find two items, a defrost heater and a defrost thermostat. You can check out the heaters with an Ohm meter. No reading, open, means replace the heater.
Posted on Jun 30, 2008
  • 159 Answers
SOURCE: my fridge is not getting cold
low gas level in the system
Posted on Oct 23, 2009
  • 2699 Answers
SOURCE: WATER DROPS AT TOP OF FRIDGE
sounds like the door was left open,make sure nothing is overhanging on the shelves preventing the door from closing next time send model number
Posted on Nov 27, 2009
caroldon
  • 17130 Answers
SOURCE: phillips whirlpool built in fridge
Could it be that there is degradation of the plastics due to heating of the defrosting coils or is it the smell off leaked gas.
Remove all the food stuff from the fridge and clean, wash the inside throughly. Now restart the fridge and after aboutone hour check for smell, continue this till you notice, if the smell comes in after about 10 hours then you must look into the defrosting heater for any traces of material on it causing the smell on heat.
Posted on Aug 30, 2010
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
The freezer is not cold enough but i don't see a temperature control inside. Does the one in the fridge also control the freezer?
Correct. The fridge works 100% off the freezer anyways. So they installed the sensor right between the freezer and fridge if you look inside you can see it.
Whirlpool refrigerator repair orange county, ca
Feb 06, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
My fridge is not getting cold
Oct 16, 2009 | Whirlpool Refrigerators
I just bought second hand Whirlpool fridge freezer, ARG/918/G/WP (8534918010180) - is there a user guide/manual available? I don't know how to set it, defrost, it or anything.
Sep 11, 2009 | Refrigerators
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
Orange star button inside fridge
Jun 29, 2008 | Haier HTX18GAAWW Air-Cooling And Automatic...
Whirlpool Fridge Model WRX57H Defrost Timer
if you couldn't find a defrost timer then just unplug it or switch it off until all the frost (ice) melts!
Nov 19, 2007 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer too cold, fridge to warm
so what is the problem or question? talk to th company u bought the refrigerator from and deman and refund or replacement
Sep 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
594 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
