Question about LG DLE2532W Electric Dryer
Loud screeching noise from dryer.
The dryer was working fine and then during a drying cycle it started making a very loud noise when it would rotate. Did a belt brake or ??? What should I look for?
  • 1 more comment
  • kkatzs1 Apr 13, 2009
    Its on certain parts of the rotation I believe. I will double check that b/c I turned it off as soon as I heard it.
    I'm pretty sure that it's during certain parts of the rotation. I will double check b/c I shut it off immediatley after hearing it.
  • Wayne Moore
    Wayne Moore May 11, 2010
    does it make the noise all the time or just at certain parts of the rotation of the drum?
  • 39 Answers
Sounds to me like the nylon pieces that isolate the drum from the front of the door are gone, you may want to open it up and take a look at it. Is it an old dryer? Its either that or I suppose it could be the bearing in the middle of the back but I dont think it would be in only certain parts of a rotation, it would be all. Im sure the drum probably just ate through the nylon seperator.Theres not much else that only makes noise part of the time.. and theres not many moving parts.
Im not sure if there are replacement pieces for this but you can google it.
Posted on Apr 13, 2009
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wq5rt
Posted on Sep 30, 2010
My maytag neptune dryer mdg5500aww is making a screeching sound. It is drying the clothes but it is getting louder by the day. What part needs to be replaced?
There are 2 wheels in the rear that the drum rotates on - one could be binding. The tensioner has a wheel, check it for rotation. Belt slipping? Check motor for operation - check that plastic blower isn't rubbing in its box. Dryers are easy to disassemble - check YouTube for procedure.
Jul 24, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Dryer makes loud noise and does not spin
had that problem once and it turned out to be 2 problems....the first was the belt that snapped..replaced it and it did not work turned out to be the pulley on motor broke
Dec 17, 2011 | Dryers
Dryer makes loud noise during drying cycle. Drying is fine otherwise.
Bearings in the drum rollers going bad or something caught in felt area of drum. Need to take dryer apart to figure which it is.
Jun 03, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
The dryer is making a loud noise-like metal on metal
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 18, 2010 | Frigidaire GLGQ2152ES Gas Dryer
My GE Harmony Dryer is making a LOUD noise during entire cycle
heatman101
yue
Jan 26, 2010 | GE Profile Harmony DPGT750EC Electric...
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
if its while filling may be water pressure try turning tap down (hot)
Apr 04, 2008 | Washing Machines
GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
LG DLE2532W Electric Dryer Logo
499 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
