Question about Sony FWD50PX2/S 50 in. Plasma Television
The screen went black
16 months after my purchase i was watching my sony 50 in. plasma tv and all of a sudden i heard a pop sound and screen went black.I tried to turn it on and off but it didn't work.it's been over a year so i'm out of warranty.not sure what to do at this point..
  • 2 more comments
  • Derek_2 Nov 04, 2007
    Did you figure out the problem. My Sony Plasma has the same problem. I heard a pop and poof, the image was all green and monotone.
  • Anonymous Nov 25, 2007
    My TV has lasted for almost 19 months. While I was watching TV it made a lout popping noise and then the screen went black. Sometimes I can see a monochrome picture but overall the TV is worthless now. It's outside the warranty so I'll have to go to a local repair shop to see if it's fixable.
  • Keeb Feb 22, 2008
    Same exact thing jus happened to mine, 20 months old and they say it is under warranty, waiting on tech, they say it may take three weeks or longer.
  • Anonymous Feb 23, 2008
    heard a pop and tv went blank
    Problem Solver:
  • 5 Answers
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Posted on Aug 09, 2008
  • 4 Answers
Happened twice to me - waiting for repair to come out now. My warranty paper says I have two years of on-site repair. Why is yours only one year??
Posted on Dec 14, 2007
This has happened to my sony TV now 3 times. The problem is that the tube or fuse in the back blows and then gives no picture. The problem can usually be fixed with a new part that can be installed at your house. However being that this is my 3rd time and has happened with other similar models I have to say Sony probably released a bad model.
Posted on Nov 19, 2007
    Sergeant:
  • 457 Answers
I tried to see where you come from but it was unspecified. If you are in the States you might be lucky....go here and have a look they might be able to fix your screen up.. http://lcdrepair.net
Posted on Sep 11, 2007
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 192 Answers
SOURCE: samsung 50 inch plasma
I have found the most common problems with the symptom you have described, to be the SMPS PCB. Sometimes the Y Main will cause the power supply to short out and lower a voltage in that area. Your set has a two year warranty. Call 1-800-Samsung to find an authorized servicer in your area.
Posted on Apr 08, 2007
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 50 inch plasma vizio tv. I was watching it then i heard a pop the screen went black and i still had sounds yesterday but today no sound, I called vizio tech support they told me it was the gas...
when you here a loud pop its usually the sustainer boards. Have you checked the fuses on the sustainer boards first to see if they are still good. There is a IC chip under the heatsink and when it gets extremely hot it gives. Also check you power supply board to make sure you don't see any swollen capacitors, leaky or bulged out from the top. Let me know if that helps at all.
Oct 26, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
LG 50inch Plasma received loud sound then went black
I suggest you guys take your TV's into a repair shop like Sears or Best Buy... The main reason most plasmas go dark is because of decay, but I don't think this is the case. Because what you describe is similar to what happens in LCD's when their back light goes out. Although you can open up and repair the back light your self in a LCD, I would not advise you to do so for a Plasma, because of the hazardous chemicals used in the plasma display plus the fact that plasmas don't use back lighting. And 2 years is way to soon for decay to be a factor. So more than likely a circuit shorted out and the TV has to be opened up to be repaired.
May 27, 2009 | LG 50PX4DR 50 in. Plasma TV
Heard a pop and screen went black
Sorry thats the death of your tv I
m afraid, the pop you heard is either your lamp or tube going boom.
Apr 03, 2009 | Televison & Video
Plasma tv repair question
Thin lines down center of ESA 42"plasma tv, about 1 pixel wide each, about 3/4" to either outside line
Started as 1 then 4 over 4 months
Aug 10, 2008 | Televison & Video
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Jan 13, 2008 | LG DU-50PX10 50 in. Plasma HDTV
Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV ready
Your projector bulb burned out, easy to replace yourself
Oct 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony FWD50PX2/S 50 in. Plasma Television Logo
233 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
