Question about Frigidaire FEF336BC Electric Kitchen Range
Fridgidaire slide in oven, everything works but oven elements
All three elements in the oven were tested and appear to be fine
are there any fuses or breakers in these units, my manual does not provide this information
Model DGES388AS4
Serial NF23813759
when this happened I had just turned oven on and shortly thereafter heard a pufff, electric breaker for this unit turned it off
I would appreicate any in fo
    Scholar:
  • 68 Answers
I would have to look for a broken or shorted wire in the back of the unit or even a burned out control board. if you heard the noise then it should be pretty easy to see the problem. pay attention the the main wires coming into the range from the wall.
Posted on Apr 29, 2009
Why won't the lower element heat?
DID U TEST THE NEW ELEMENT B4 TRYING IT? U MIGHT BE SURPRISE. OTHER WISE I WOULD D SAY CHECK THE WIRING AND CONNECTIONS IF ITS NOT WORKING, CHECK FOR VOLTAGE AT THE CONNECTORS?
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Jun 25, 2015 | Ovens
Oven not working everything else works fine
THINGS TO CHECK:
the broil element
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 13, 2015 | Ovens
I have a tricity benfix electric oven.. My main oven and top oven have both stopped working, but my hob and grill work fine, how do I fix my ovens? What the problem?
THINGS TO CHECK:
the broil element
The bake element
Mar 20, 2015 | Ovens
Oven
THINGS TO CHECK:
the broil element
The bake element
Apr 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire electric range model ES100 oven wont heat. everything else works and lights up but no heat in oven
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
THINGS TO CHECK:
the broil element
The bake element
Apr 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
The oven will not heat up. model # RF315PXEW serial # RG3219362 i was cleaning it and the top element( where the connector slides onto the element) touched the back of the stove and created a spark. i...
Test element for continuity first and if it has continuity you need to look elsewhere, possibly at they switch or thermostat as you said you shorted it out, let me know after you have done continuity and i will help you further if required, David "The Famous Forry"
Sep 30, 2017 | Whirlpool Ovens
Oven won't heat or clean but broiler works
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 11, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Nov 12, 2007 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
226 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
