Question about IBM Corded Phone IBM412CID
Date and time
In the lcd it is showing April and it is September. The time is off also. I cannot figure out how to set it. It is moving right along and changing daily (the date) But it would be nice to show the correct info.
To set your clock and calendar do this:
1. press shift
2. press set
3. enter 2 digits for month 01-12
4. enter 2 digits for day 01-31
5. enter day of week ( 1-7) 1 is for sunday, 2 Mon, ect
6.enter 2 digits for hour from 1-12
7. enter 2 digits for minute from 00-59
8. enter AM or PM (* for AM) (# for PM)
9. a short ring will be heard to signal you completed it
successfully
Posted on Dec 21, 2007
I am flying to Tokyo on the 24th of March and returning on the 13th of April. My UK passport expires in mid August. Is my passport valid for travel or do I need to renew it.?
if the 24th of March and 13th of April are in the same year, preceding the mid-August expiration date - it is valid for travel.
Feb 24, 2015 | Miscellaneous
How set to time and date on brother intellifax 2820
Setting the Date and Time
Your FAX/MFC displays the date and time and prints it on every fax you send.
In the event of a power failure, you may have to reset the date and time. All other
settings remain unaffected.
1. Press Menu/Set, 1, 2.
2. Enter the last two digits of the year, and then press Menu/Set.
3. Enter two digits for the month (for example, enter 09 for September, or 10
for October), and then press Menu/Set.
4. Enter two digits for the day (for example, 06), and then press Menu/Set.
5. Enter the time in 24-hour format (for example, enter 15:25 for 3:25 PM),
6. Press Stop/Exit.
The LCD now shows the date and time.
Sep 25, 2011 | Brother IntelliFax-2820 Laser Fax
Hello, i am trying to find out when the MDE6400AYA was made.. What year
Hello there.
You will need to write down your SERIAL number from your model/serial tag.
Example: 15114672UY...... UY is the date code. First letter is the year, second letter-month.
1980 E March
1981 G April
1982 J May
1983 L June
1984 N July
1985 P August
1986 R September
1987 T October
1988 V November
1989 X December
1990 B Jan.
1991 D Feb.
1992 F March
1993 H April
1994 K May
1995 M June
1996 Q July
1997 S Aug.
1998 U September
1999 W Oct.
2000 Y Nov.
2001 Z Dec.
2002 A Jan.
2003 C Feb.
2004 E Mar.
2005 G April
2006 J May
2007 L June
Hope that helps,
Mike
Jul 27, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
How do I change the time on the Brother 2820 fax?
This was taken directly from the Brother 2820 Manual:
Setting the Time
When the machine is not in use it will display the date and time. If you set up the Station ID the date and time displayed by your machine will be printed on every fax you send. If there is a power failure, you may have to reset the date and time. No other settings will be affected.
1 Press Menu/Set, 0, 2.
[2. Date/Time]
2 Enter the last two digits of the year.
Press Menu/Set.
3 Enter two digits for the month.
Press Menu/Set.
(For example, enter 09 for September,
or 10 for October.)
4 Enter two digits for the day.
Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
whenever the machine is idle in Fax
mode.
When the machine is in Sleep mode, the
LCD shows Sleep. (See Sleep Time on
page 2-8.)
Turning on Automatic Daylight Savings Time
You can set the machine to change automatically for Daylight Savings Time. It will reset itself forward one hour in the Spring and backward one hour in the Fall. Make sure you have set the correct date and time in the Date/Time setting.
1 Press Menu/Set, 1, 5.
[5. Auto Daylight]
2 Press Up Arrow or Down Arrow to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
May 03, 2011 | Brother IntelliFax-2820 Laser Fax
Hello we have a Brother 2820 Fax Machine and we cannot find the Instruction Manual and we need to reset the time can you please advise us on how to do it. Thanks Marie
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
5 Enter the time in 24-Hour format. Press Menu/Set.
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
Apr 07, 2011 | Brother Office Equipment & Supplies
How to set the date and the time in brother fax mfc-8220? what's the steps?
Your MFC displays the date and time and if you set up the Station ID
it prints on every fax you send. If there is a power failure, you may
have to reset the date and time. All other settings will not be affected.
1 Press Menu, 0, 2.
Press Set.
Press Set.
Press Set.
Press Set.
6 Press Stop/Exit.
The LCD now shows the date and time whenever the MFC is in
Standby mode.
thx, if this helps please rate :)
Jan 27, 2011 | Brother MFC-8220 Fax
How do i set the date on Brother intellifax 2820?
In the event of a power failure, you may have to reset the date and time. All other settings remain unaffected.
1 Press Menu/Set, 1, 2.
2 Enter the last two digits of the year, and then press Menu/Set.
3 Enter two digits for the month (for example, enter 09 for September, or 10
4 Enter two digits for the day (for example, 06), and then press Menu/Set.
5 Enter the time in 24-hour format (for example, enter 15:25 for 3:25 PM),
6 Press Stop/Exit.
Dec 02, 2010 | Brother IntelliFax-2820 Laser Fax
How do I change date and time on my fax printout?
1/ Press menu/set
2/ Enter the last 2 digits of the year. Press menu/set
3/ Enter 2 digits for the month. Press menu/set
(For example press 09 for September, or 10 for October.)
4/ Enter two digits for the day. Press menu/set
5/ Enter the time in 24 Hour format. Press menu/set
6/ Press stop/exit
Nov 30, 2010 | Brother MFC 7420 All-In-One Laser Printer
Change the date and time
Press Menu/Set.
Press Menu/Set.
or 10 for October.)
Press Menu/Set.
Press Menu/Set.
6 Press Stop/Exit.
mode.
LCD shows Sleep.
Jun 25, 2010 | Brother MFC-7220 All-In-One Laser Printer
Zenith Redi_set clock radio Z230S
Describe your problem: Depress MONTH/DATE and ALARM1 for 3 seconds and display will show DST 'start' month,week,and date.
Display will show 4F 4.1, alternately flashing
4F = April First week. 4.1 = April 1.That is the old dates for change. What we want to do is to change to the new dates. Once it is done, it will change in the new dates as it did on the
old dates..
Hold down the MONTH/DATE button for 5 seconds, and while pressing the - or down button3 times, until the display shows '3'F2.
3 is month F2 is the week.
=March 2nd week.
You have successfully change the March changeover.
Now for the November change.
Depress and hold MONTH/DATE and ALARM2 after 3 second the display will show DST 'end' month,week, and date.
First digit will be 10 =month. second digit will be L=Last week, and date, will flash alternately.
While holding down the MONTH/DATE press the + or UP button once the display will show 11 (November) and F (first week) and 1 as date alternately flashing.
You have successfully set it for the next 100 years
Apr 17, 2009 | Zenith Z230S Clock Radio
IBM Corded Phone IBM412CID Logo
169 people viewed this question
Top IBM Lands Phones Experts
Marvin
Marvin
k24674
Are you an IBM Lands Phone Expert? Answer questions, earn points and help others
