Question about Zanussi Washing Machines
Won't spin Zanussi front load washing machine modelFL1084 wno't spin, will pump out, have checked filter and drainage hose
  • 744 Answers
Hi..
What happens is the machine will stop spinning because the door latch will fail to lock. Deep inside it is caused by the mechanism that locks the door. The wax motor will draw too much current and damage the control board by burning a resistor (R11)
just pull the board u can discover burn thru on r11 (you can see the blackened resistor). orders and new board & wax motor on ebay. open the washer & replace the board & wax motor..
thank u
rate me!!!
Posted on Apr 13, 2009
Not rinsing or spinning
CHECK ON THE DRAINAGE WATER OUTLET PUMP,,,,,,,,,,,,ITS BENEATH THE FLOOR OF THE WASHER, IT HAS AN OPEN,,,,CHECK MAYBE THERE IS AN ABSTACLES IN THE PUMP CUP OR THE PUMP NEEDS A CHANGE
Feb 24, 2012 | Zanussi WJD1257S Front Load Washer
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Washes clothes fine but won't go into spin cycle.
Could be that the load is either a) too big or b) unbalanced. Try removing some items then set to spin again.
Alternatively it could be that the water is not pumping out. Check the hose from the machine to the drain. Check the filter / junk catcher. Check the hose between the drum and the pump.
I have also had machines that will wash but not spin because the carbon brushes for the motor were worn out. It is not a difficult or expensive job to change the brushes yourself.
Jan 15, 2011 | Zanussi FJD1666W Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
ZWF1630W
I trust that the drum can be turned by hand.It seems like the filter is blocked you will have to drain the water and remove the filter check that it is clean and the pump is free,with filter out put to spin or drain and see that the pump blade is spinning if not then something is jammed in pump try to free and then replace filter and check for leaks.Check also drain hose not kinked or drain blocked.Hope this helps.
Apr 28, 2010 | Zanussi ZWF1630 Front Load Washer
THE WASH REACCHES DRAIN AND SPIN STOPS THEN ENDS CYCLE
pump is blocked check your filter at the front some have a small drainage tube there to remove the water. failing that tilt back machine slighty open door and remove with a jug, remove filter uscrew and pull and check for foriegn objects i.e coins screws,whilst tilted back squeeze the two rubber tubes to the pump to make sure they are clear or unclip if need be MAKE SURE POWERS OFF lay some towels down sit machine back down slowly there will be excess water and with filter out run machine SPIN ONLY if it does you've solved your problem also check your waste and outlet pipe your waste could be pushed too far down the outlet pipe 6" is adequate enough.good luck
May 18, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
