Question about Theater Research TR-9500 Car Subwoofer Box Car Speaker
Need to hook up to a 4000 watt amp
Wire 3 15 in cvr to a4000 watt amp
  • Anonymous Mar 28, 2014
    wire diagram the best way to run it
  • 32 Answers
Why would you hook up 4000 watt amp to a speaker that has only 1000 watts. Try a 800 watt amp instead unless you just dont want the spealers.
Posted on Jun 14, 2009
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
Brand new pioneer 820 watt amp worked for about ten minutes, now the speaker output light flashes on and off
You didn,t have the sub wire up properly, End fried the output transisters in the amp. Or it was not set (Properly)
Nov 05, 2012 | Pioneer Car Audio & Video
I have two Kicker dvc cvr's 12's and I want to hook them up to a Kenwood KAC-520 1000 watt amp. Whats the best wiring to wire these?
The best thing to do would be to get an amp installation kit, at an auto stereo store or Wal-Mart automotive department. It will have the wiring and connects that you'll need to wire everything up.
May 19, 2010 | Car Audio & Video
Amp turns off.
your drawing/pulling too many amps. Is it a mono(one speaker), two way(two speakers/can be briged to one), or a four way(four speakers/can be brigrd to two). don't put too many speaker to that one amp if it's only a mono, or a two way.
Sep 24, 2009 | Kenwood KAC-9152D Car Audio Amplifier
How do you wire four 12 inch kicker cvr dual voice coil, to a 2400 watt 1 channel class d amp
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
Jun 07, 2009 | Kicker CVR12 Car Subwoofer
How do i hook them up to work for 2ohm's
Hello rcantu76,
If your CVR's are 2ohm (model Nr. 07CVR122), you connect the voice coils in series and then parallel both subs to the amp. If the subs are 4ohm (model Nr. 07CVR122), they cannot be wired to 2ohms. Your choices are 1ohm or 4ohms. According to Rockford-Fosgate's data on the P1000-1bd, it is stable at 1ohm.
To wire the 122's at 2ohms, you would connect the sub voice coils in series (jumper one positive to the other negative on each sub), and then connect the remaining positives and negatives to the amp.
To wire the 124's at 1ohm, you would connect all of the positives and all of the negatives together to the amp.
Hope this helps.
May 11, 2009 | Jl Audio 500/1 Car Audio Amplifier
What amp will push 2 kicker 15inch cvr's
Hello herb31,
Kicker lists the RMS power handling range of the CVR's from 100-500 watts, with a peak power capability of 1000 watts. There are lots of monoblock amps within that range. It just depends on how loud you want them and how much you want to spend.
In the low range, an amp like the Alpine MRP-M500 will deliver 250 watts to each sub at 2 ohms. And it only costs $179. Currently, the MRP-M500 is out of stock at Crutchfield. I just bought the last one. So my 2nd recommendation would be the Sony XM-1S, which has the same power rating and according to Crutchfield is no slouch either. It's also $179. I really like the Sony, too. It has a small footprint that makes it easy to find a convenient mounting location. Both the Sony and the Alpine are CEA-2006 compliant, so you can be sure that the manufacturer provided specifications are not overrated. Assuming that your vehicle electrical system can deliver the current, both the Sony and the Alpine will deliver an honest 250 watts RMS to each of your Kickers. And 250 watts will make them kick pretty darned good.
In the medium power range, consider either the JL Audio G Series G1700 which delivers 700 watts into 2 ohms. It costs $419 at Crutchfield. Or perhaps the Kicker 08ZX750 with 750 watts at a cost of $399.
To push the CVR's really hard, close to their 500 watt RMS maximum power range, look for an amp that delivers 1000 watts. In this range, you will definitely some heavy-duty wiring, electrical system upgrades, perhaps a 2 farad capacitor, and be ready to spend at least $600 on the amp. Your best combination of power and price would be another Alpine, the PDX-1.1000M, at $799. If you buy one from Crutchfield, they will throw in a 4-gauge amp wiring kit. And if you use a "friend referral code", such as mine, which is p7sdj-hrx8q-9800g, and your order is at least $200, you'll get another $20 discount. And I get a $20 credit toward a future order.
Hope this helps. If it does, please rate as "FixYa".
Apr 23, 2009 | Kicker KX1200.1 Car Audio Amplifier
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Theater Research TR-9500 Car Subwoofer Box Car Speaker Logo
457 people viewed this question
Top Theater Research Car Audio & Video Experts
xxxxxx xxx
Are you a Theater Research Car Audio and Video Expert? Answer questions, earn points and help others
