Question about Ricoh Aficio 2022 All-In-One Laser Printer
Won't receive all pages of a fax. Generating service codes 00-83
Copier machine is a RIcoh Aficio 2022
  • 1 more comment
  • cunliffe415 Apr 13, 2009
    Our Ricoh photocopier Aficio 2022 will only receive one, sometimes two pages of a fax at a time. Then the error report page prints "service code 00-83" or sometimes "06-02". Any suggestions?
    Thanks ,
    MArcia
    Yes it was the phone cord which was cracked and causing static on the line. THank you.
  • Anonymous May 11, 2010
    Please explain again, your problem is not visible in the heading.
That could be caused by a number of things:
Are you connected to the phone line by a very long telephone cable? This can cause extra interference and cause these codes. Or it could be a deteriorated cable...try another one.
otherwise, it could be a fax circuit board problem, but more likely you need to have the 'cable equalizer " adjustment performed in "service mode", which is a fairly simple adjustment for a service tech, but too complicated to explain here.
I hope this helps.
Posted on Apr 13, 2009
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Looking for an owners manual for a Ricoh Aficio SP 2022
I do not have a manual for the Aficio 2022SP. However, there is a manual for the Ricoh Aficio 2022 available as a PDF here: http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio2022-27.pdf . If the direct link doesn't work, start here: http://www.ricoh-usa.com/downloads/downloads.aspx?d=pm and search for the 2022.
I hope this helps.
Feb 11, 2011 | Office Equipment & Supplies
Where is the hard drive located on a ricoh aficio 2022
i don't think there is hard drive, but there is memory inside
Feb 02, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
I HAVE A COPIER RICOH AFICIO 2022 SP WITH THE CODE SP 545 BUT I WANT TO KNOW WHERE IS THE THERMISTORS TO CLEAN IT
Thermistor is in the fuser. Open right cover and you see the fuser. On a fuser have some labels "Hot Surface" "Danger... or something
Jan 24, 2011 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Hi, we cannot print to the Ricoh Aficio 2022. I have connected to the printer by pinging the IP address of it and it is OK. The 2022 can still photocopy. I have tried a test page and nothing prints.
Are you sure no other device on your network has the same IP address? (Turn the copier off and trying pinging that IP address to make sure.)
Do you have the Ricoh 2022 driver installed? You can download it from Ricoh-USA.com if you don't have it.
Aug 23, 2010 | Ricoh Aficio 2022 Black and White Copier
I turn on my ricoh aficio copier 2022 this code sc998 appear
The meaning of the error sc998 is the system software does not start within 60 sec.The cause for that is either the RAM, DIMM (software SD cards), firmware(system software) or the main controller is faulty or not connected properly.
Did you remove chip or SD card from the machine?
Mar 11, 2010 | Ricoh Aficio 2022 Black and White Copier
I have a Ricoh Aficio 2022 which displays a service code SC545. Anyone know what this means. Do I need a tecnician to fix? Thanks Steve
This is a fuser overheating problem. I'd try to clean the thermistors and make sure they are touching the hot roller then use SP810 to reset the code. (clear modes, 1,0,7,hold down the clear stop key, enter COPIER SP mode,then go to SP810 and hit execute.
Sep 07, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 2022 All-In-One Laser Printer Logo
2,177 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
