Question about Maytag MEC5430BDS Electric Cooktop
I have a Maytag Precision Control 500 Electric Smoothtop Stove, Model # PER5750QCW. My oven has stopped working but all the controls are still working, do I need to change a fuse? If so, where are they located? Any information regarding this problem would be greatly appreciated.
  • pocobear12 Apr 27, 2009
    I have the exact same oven but my problem is that it takes forever to heat up. It takes an hour to heat up frozen fries. I think we may both have a faulty element problem. The oven eventually reaches temp but if the door is opened it drops drastically
One or both of the elements is gone, replace
Posted on Apr 27, 2009
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
MY maytag flashes a error code while trying to self clean. It is a MER7765
No the stove don't work right then you have to have a repair man look at that.
Jan 19, 2013 | Maytag MER7765WW Freestanding Smoothtop...
I have the jenn air smoothtop model number jes8850bcs and the buttons on the front control panel are not working the bake or convect. Some of the buttons still beep and work but the oven portion does not....
I had the same problem... resetting the breaker fixed it for a while but it the problem always represented itself. Replacing the temperature sensor at the rear of the stove finally solved the problem. My problems started after doing a "self clean"
Oct 23, 2010 | Jenn-Air JED8430 Electric Cooktop
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Jul 08, 2010 | Maytag MEC5430BDS Electric Cooktop
The on indicator light stay on all the time on Maytag touch 500
you have a bad switch, you need to unplug the wire going to the conector marked P on one switch at a time til you find witch switch is bad. if you have turned off the breaker to it and the light is still on then the power is not off to it there is not a batery in it, careful that glass breaks easy when out of it's can
Dec 25, 2009 | Maytag MEC5430BDS Electric Cooktop
One surface element went dead.
Make sure that element didnt come unplugged. Just push it in firmly and it should be fine.
Mar 18, 2009 | Cooktops
Maytag, precision control 500 [canada]
the infamous "custom control kit" its an electronic board that only control that one precision temp burner all other elements ar regular switches, if thats the one where the sound os coming form replace the control. .nothing else to do
Dec 26, 2007 | Maytag MEC5430BDS Electric Cooktop
Maytag,electric stove-
you need to order a custom control kit, electronic switch that contorls onlly that one burner
Dec 07, 2007 | Maytag MEC5430BDS Electric Cooktop
Maytag MEC5430BDS Electric Cooktop Logo
464 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
