Question about Intel Motherboard
Front panel connector
How toconnect wire on msi mainboard. computer not booting up because of these wirers installed in the wrong place help me
  • Venturefan Dec 13, 2007
    I need a diagram to show where the wires need to be placed for the Front Panel connections on a K9MMV Motherboard. Thanks
  • Anonymous May 09, 2008
    I can't switch my computer on because i cannot connet the front panel connecters, Please help.
    New Friend:
  • 99 Answers
First of all remove the front panel connectors before powering up, cause U do not want to put any wires to the USB headers. In doing so u might damage u'r board Second get your hands on the mother board manual,, if the front header has no label printing indicating the connection details. If no manual. then get on line and do a google search you'll find plenty of info's on how to DIY. Happy hunting Rifaa
Posted on Sep 11, 2007
Power problam
Hello the manual can be downloaded here:
Please unzip the file when downloaded.
You will also need adobe reader to read the content.
Try to renew the power supply.
I think that`s why the mainboard is not having any power.
Look also for the front panel on off connector, is not connected wrong.
If no luck changeing the power supply, the mainboard probably has a internal fault, and must be renewed.
Good luck
Apr 20, 2013 | MSI 945GCM5 Motherboard
Wiring diagram for ms 7069
Hello here is the homepage:
This mainboard is a OEM manufactured by msi for NEC.
The support belongs to nec, and there is nothing to be found at the msi homepage.
Basicly its just to connect the 20 or 24 pin power connector, and the 4 pin atx power supply.
Next connect the power to the dvd and harddrive.
Then connect the data cable from the drives to the mainboard.
The front panel connector looks like this:
This is basicly the same for all msi mainboards.
Next you can power up the pc, and enter the bios and set the boot order ( press the delete button when posting )
Lay the windows disk in the dvd drive, and leave the bios and save your settings.
Now your ready to install windows.
The drivers can be downloaded here:
Best of luck
Mar 18, 2013 | MSI : MS-7061-020...
I have recently installed windows 7 but there is no audio sound i think drivers have not been installed that is why my computer is lack of audio sound to hear a music please make a hand to me i mean h
Here is no sound drivers for windows 7.
If i am wrong by the mainboard model, enter the ms xxxx number here:
The ms number is located on the mainboard.
The solution is to buy a sound card, to add on the mainboard.
You just have to make sure, the driver is available for your windows system.
A sound card, can be bought online, or in a computershop.
As i know, MSI is not planning to make drivers, for this mainboard for windows 7.
Good luck
Feb 01, 2013 | MSI K8N Neo4/SLI Motherboard
How to check a G41MXE motherboard
Hello the mainboard home page is here:
Try to download a manual and check the mainboard up
for any loose connections i mean the front panel wire
so the mainboard can start.
The power switch cable or ON/OFF must be placed correctly.
If no luck the board is dead.
The front panel connector look like this:
Good luck
Nov 02, 2012 | Foxconn G41MXE Motherboard
Hi Mr. Smith,
You cant find that boot disket on internet. Only MSI peoples can help you. Here is the download link for you.
So.. happy download and write everything on a CD/DVD first.
Link :
Mar 16, 2012 | Computers & Internet
Installed New Motherboard Computer Cycles off and on when I push the start button, I have to play with the reset button several times before it will Boot.
Check that the Processor is seated properly and locked in place. Also, reseat the memory.
Re-check all your power supply connections.
Are the front panel connectors in the correct place?
May 19, 2011 | MSI G31TMP21 (890552671946) Motherboard
Download the manual for you're MSI PM8M-V motherboard from MSI;
You will need to download and install Adobe reader to view the manual. Download Adobe;
Open manual to page 9. See Front Panel Connectors: JFP1 & JFP2. There is no need to connect JFP2's Power LED jumper, this is completed at JFP1. Each wire jumper coming from the case will have one wire color in common with all connectors except the speaker jumper. That common colored wire will be use as negative.
The speaker wire commonly as red is positive and black is negative.
Apr 22, 2010 | MSI PM8M-V Motherboard
My computer sometime do not boot, I've got a black screen (No Signal) and hangs there until I unplug the computer from power line. My configuration is: MSI P35 Platinum Combo Bios V1.2(updated), Q6600,...
there are a lot of causes of black screen.. check the ram, or cpu.. or the vga connector.. about the booting.. be sure that your operating system is good.. if not of course not booting anymore
Sep 12, 2009 | Computers & Internet
Help with front panel cables connection, case to mainboard.
The best place to look would be Click on the support link and lookup your specific board model #. All drivers, and manuals should be available there for free download. Hope this helps.
May 04, 2009 | Computers & Internet
How do hook up front panel power switch to motherboard
The simple way is to remove the front panel of the computer trace the wires to the front panel leds, make note of color pair to each led. The using the manual that came with the motherboard locate the schematic for the JFP1 connector on the motherboard, it show's where the leds wires connect to operate. If you have no manual, if you look very closely at the connector you will see where the led wires connect, you may have to use a magnifiying glass and flash light. You cannot damage anything if you accidently place the led wires in the wrong place. If the panel led wires are in a single connector and won't work on the motherboard, you can remove the wires from the connector by using a very small sharp pointed pick to push down the retaining tab on each wire, thus enabling it to be removed from the connector, just be patient. BPCS
Dec 31, 2007 | E-Machines eMachines Desktop PC
Intel Motherboard Logo
116 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
