Question about HP Photosmart C3180 All-In-One InkJet Printer
Short-lived cartridges. What to do think of using ink filling services?
My cartridges are used up very fast. My photosmart is a printer, scanner and photocopier. i tried to copy a letter using the black. onl the first line came out. I tried using the color cartridge and the first line came out black and the rest was very fainty. What do yo think of having the cartridges filled instead of replaced? My how how I grieve for my typewritiers and the cheap ribbons. Thankyou very much. ow how do i find your answer?
  • 700 Answers
If you are not after its printing quality then refill is an alternative. Also point to consider; is it almost at par with the original, availability in your location, replacement/repair or support, price vs original.
Posted on Apr 13, 2009
My printer is refusing to print.it makes a deceptive sound that makes one to think printing is on but to no avail.please i need urgent help.
along the top of the unit behind the cart is a plastic strip
its a vernier strip its lots of ''''''''' all the way along
the print head uses it to know where it is
i think either the sensor that reads the strip {ir TXRX led }
or the strip is dirty or worn
Jan 10, 2015 | HP Photosmart C4480 Color Printer Scanner...
Can the hp4180 run with just the black ink cartridge filled with ink and not the color cartridge
no, I don't think that it is recommended to run with just the black ink cartridge filled and no color cartridge.
But, you can try it, as some hp printers do work that way.
The instructions say that low ink cartridges should be replaced to get the best print quality.
Jan 01, 2011 | HP Photosmart 4180 All-in-One Printer
I am having a problem printing with my HP printer
you wasted your time using cleaning program and heaps of ink...
follow this procedure:
1. remove all ink cartridges from the printer
2. check if ink is soluble in water, isopropyl alcohol or methylated spirit (this which do not create lumps or precipitations is correct solvent)
3. put one drop of solvent in th centre of aspiration hole on receptable
4. if solvent is absorbed through input, that meant problem is not with printer but with cartridges.
5. check printer cartridge by stamping them with tissue if they "produce" any ink on the outlet,
6. put one drop of solvent on cartridge outlet and insert them in correct bases
7. print test page, print should be rather weak as solvent will go through the nozzles
8. print test page from computer
9.create "strip page" of each colour used, separate by no colour (white) start with yellow strip, then white, light cyan, white, cyan, white, light magenta, white, magenta, white, black - this strip pattern will force all cartridge to operate on they max delivery.
if there is no result, service by technician will be in place...
all ink based printers need to print at least one page per week... ink will dry pretty fast, especially in dry or hot condition.
Jul 28, 2010 | HP C6250 InkJet Printer
Poor print quality
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 17, 2010 | HP Photosmart Premium C309A All-In-One...
Can I reset the chip to use remanufactured ink?
As the owner of a Cartridge World I can tell you that there is not currently an effective way to reset or replace the chip for HP 564 series cartridges. One of our supplies is hoping to have a solution this quarter.
Jan 14, 2010 | HP Photosmart C6380 All-In-One InkJet...
Had black ink cartridge filled, but now the
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 18, 2009 | HP Photosmart C7250 All-In-One Thermal...
I am missing a ink cartridge and my hp photosmart C4580 wont let me use my scanner
This is because printer and scanner are connected together.The printer need both cartridges installed to initialized and then initialized the scanner.Just put the missing cartridge and problem will solve.
Oct 29, 2009 | HP Photosmart C4580 All-in-One InkJet...
"Color Ink Probelm"
Don
Oct 24, 2009 | HP Photosmart 2575 All-In-One Printer,...
Excessive use of ink
Sorry, HP's main objective is to sell ink.
Jan 09, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
HP Photosmart C3180 All-In-One InkJet Printer Logo
55 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
