Question about Air Purifiers
Ozone function causing blue spark and snapping
My Eco Quest Breeze machine is making a snapping noise and I can see a blue spark when the ozone maker is turned on.
  • 80 Answers
Contact healthytech@triad.rr.com. They will be glad to help you.
Posted on Apr 15, 2009
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
My Breeze AT by EcoQuest , Model Breeze AT, Serial AT 125386, is sizzling the only ozone plate it has. A sizzling sound and a visual inspection shows it has a heavy concentration of voltage near the...
DO NOT USE IT WITH A DEFECTIVE PLATE!!!
It should be used with 2 plates. Order new plates IMMEDIATELY. They aren't too expensive, and hopefully will save your machine if it hasn't been damaged too severely.
Call Vollara (new name for EcoQuest) (1-800-989-2299) and use #16618 as your Dealer Referral number.
Jan 24, 2011 | Ecoquest Breeze AT Living Air Purifier
I need an ionization wire for my ioninc breeze quadra air purifier where can I find one?
Any system using electric currents are deadly OZONE producers if your ozone producing machine is broken pleas don't fix it replace it look for any system with a filter not a electric current burning all the dust
Jun 28, 2010 | Sharper Image Ionic Breeze GP SI720 Air...
Is there ozone released from The Quadra Sharper Image #S1867 ? And if so am I causing a health problem by using it/
YES!!!!! please remove it from your home as SOON as possible it is deadly ozone and these machines have been outlawed in the state of california
Jun 28, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Our Eco-Quest Breeze no longer works. I cleaned
I've seen several like that and found the wire connections corroded off. Easy to fix if that's the case. Make sure the unit is UNplugged before taking it apart.
Sep 03, 2009 | Air Purifiers
Ionic Breeze Repair
Ionic Breeze GP. Unit was working. Removed insert to clean. Now the unit will not turn on.
Jun 11, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Question
Presumably it meets all relevant safety standards, otherwise it would not be permitted to be on the market in most civilized countries.  That said, it certainly produces ozone which, while a highly effective odor destroyer, is an environmental pollutant and causes upper respiratory tract irritation and other symptoms (check out ozone in wikipedia, and you won't want to be around it for long!).
Personally, writing as a qualified chemist and biologist, I would not want to be in the same room as a working ozone generator.
Does that help?
Mar 06, 2009 | Honeywell HFD-130 Air Purifier
Shortness of breath, coughing when working out near unit.
I think you've answered your own question: "symptoms cease when unit is turned off".
I don't want to be alarmist, and I certainly do not suggest that there is anything unsafe about the Breeze AT.  Nevertheless, this machine generates ozone, which is an upper respiratory tract irritant.  It is absolutely vital that you follow the manufacturer's instructions to the letter when operating it. Personally, I would never want to be in the same room as a working ozone generator (and I know of at least one ozone generator where the instructions specifically tell you to keep out while it's working).
Your machine may be on a setting where it is producing more ozone than is desirable. If you no longer have the manual, you can download a copy at www.ecoquest.com (click on the DOWNLOADS tab, then on OTHER on the green bar. The Breeze AT is in the Owner's Manuals list.).
If in doubt, play safe!
Mar 05, 2009 | Ecoquest Breeze AT Living Air Purifier
No ozone smell
This generally indicates that the plate is cracked or not making proper contact. Pull the plate and look very closely as even a tiny microscopic crack anywhere on the plate will produce these results.
Nov 08, 2008 | Ecoquest Breeze AT Living Air Purifier
My machine needs an overhaul?
Oct 27, 2008 | Ecoquest Breeze AT Living Air Purifier
Air Purifiers Logo
372 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
