Question about Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas / Max E Glas
Removing a staRite pump
I am removing a StaRite pump P2RA.How do I seperate the pump from the filter housing?
  • amanforallre May 11, 2010
    Do you mean remove the strainer tank from the pump? or separate the the motor from the pump?
  • Sta Rite Master
  • 1,358 Answers
A picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Posted on Nov 02, 2011
    New Friend:
  • 77 Answers
To separate the strainer tank(filter housing?) from the pump/motor take out the strainer basket and remove the four hex bolts and tank will separate.
Posted on Apr 24, 2009
Why motor hums but impeller does not turn
with motor off try turning the shaft of the motor from the back a few times then try to start up again if it doesnt need a new motor
Jun 07, 2014 | Pentair STARITE PUMP HOUSING / TANK BODY
I have- starite pump it was working fine last night but this morning there was no pressure at all i wonder if is the water tank the pump is running fine but there is no water
It sounds like you have blown your shaft-seal. When this happens the pump runs dry. If you know that you have water but it will not pump, and all the cover and housing o-rings are good, it is the shaft seal. (unless the internal impeller is just broke, but this is unlikely)
Fix: Turn off power. Remove V-clamp holding wet end together. Remove diffuser inside wet end (need flathead screwdriver).
next remove rear electrical panel on the motor. Using s 7/16" wrend, hold the end of the motor shaft by the electrical end (where you removed the cover) while turning the impeller counter clockwise (note: some impellers have an impeller screw inside which unthreads CLOCKWISE) untill impeller is off. Replace carbon shaft seal inside. Reverse and prime and then restore power and start.
Oct 20, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
High Pressure: STARITE 1.5 hp pump designed to
It is a cartridge issue in my opinion. I dont recommend cartridges ... Sand is so much superior as a filter medial. If this is an option for you ... I recommend it. If not an option, you might be able to get a different type cartridge that will filter at a lower rate and not get as dirty as fast ...
Jul 31, 2010 | Sta Rite Max E Pro 1 12 Hp Up Rate...
I turned my starite pump on and it just hummed for about 5 seconds then cut off. What could be wrong?
Your pump motor or impeller is seized. Disassemble the pump housing and check the impeller to see if it spins freely. If not then check for debris, if impeller appears to be free of debris, then check the shaft seal and motor. If the shaft seal is leaking water, then the motor bearing is likely rusted and will need to be replaced. There are 2 bearings, replace them both along with the shaft seal
Apr 11, 2010 | Pentair STARITE PUMP HOUSING / TANK BODY
Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas / Max E Glas Logo
432 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
