Question about Hoover 24 in. HD98E Built-in Dishwasher
Dishwasher Hoover HD98E
Hi, My problem is that when I start a cycle the proframme starts and goes through its normal pgramme for a while but then stops and E3 Starts to flash on the display and when I open the machine the waste water is still there. I start it again and the waste goes away so there is no problem with the waste pipe. I wonder if anyone out there knows what E3 being displayed is and what is going wrong. Mick
  • Scubby Apr 04, 2009
    It is the same problem, but an engineer has told me the heater element and the thermostat are working fine as he has tested the temperture whilst it was running.
    However periodically the E3 error is still reported. is this something I can fix?
  • Anonymous May 08, 2009
    My dishwasher is producing a pervasive odour like mouldy dankness....during wash cycles it will seemingly randomly produce the E3 message and then if you put the machine onto a cycle it will clear and be fine, until the next time. It also frequently does not correctly release the tablet leaving the flap open but the tablet stuck, al wet and gummy, to the door
    Problem Solver:
  • 5 Answers
E3 means water is "not heating" for this model. Check the heating element, thermostat/thermistor or printed circuit board with power OFF.
Posted on Jan 25, 2008
SOURCE:
Powerpoint dishwasher flashing E1 any solutions please
E1 is commonly know as a leakage error which occurs due to the excessive RPM of Washing Motor happened during Wash cycle due to water leakage. To start with check if there is a water leakage in hose connections, motor water seal leakage of sump assembly or water is leaked due to damages. Replace the connections of Hose if bad. Also check the point of damages and repair or replace the related parts.
Mar 07, 2012 | Hoover 24 in. HD98E Built-in Dishwasher
Hoover Whisper dishwasher has not been cleaning very well for a while. Had 2 technicians in, but still not working. The latest I got an e3 error on the screen. Would like to know if I can fix it or not....
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 17, 2011 | Hoover 24 in. HD98E Built-in Dishwasher
Tablets not disolving
run tap water until it's as hot as it gets.....
Nov 22, 2010 | Hoover 24 in. HD98E Built-in Dishwasher
Error 4
check out the following link... i think it will be useful for u...
http://www.fixya.com/support/t1213494-dishwasher_flashing_error_code
thank you good luck
Jun 02, 2009 | Hoover 24 in. HD98E Built-in Dishwasher
Our Hoover HD98E Dishwasher stopped working properly today. After a while the machine stops during the power spray cycle and just buzzes as though the pump is powered but not spraying. Is this the pressure...
its possible that your timer has a bad contack at this spot the machine stops but the drain valves open try advancing the timer one notch to see if it will work if yes relace the timer thanks from gilles
Mar 14, 2009 | Hoover 24 in. DT999 Free-Standing...
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
Arms not rotating
pull out washer disconnect lines unplug it open the door pull out the racks(room to work) look for any stray parts laying at the bottom(small black belt,srews any metal debris)if you find any of that try to find where it came off of.it sounds like a pump problem easy fix connect hoses to pump and mount the pump.check all hoses and spray tips thoroughly
Nov 08, 2008 | Hoover 24 in. HD98E Built-in Dishwasher
Dishwasher starts for seconds but, then shuts off
Check that water supply is available and that water inlet valve is operational. Filling unit is usually the first step of any wash program and dishwasher is shutting down because float valve is not actuated.
Jan 25, 2008 | Hoover 24 in. HD98E Built-in Dishwasher
DISHWASHERHD98E
you have probably flooded the base of the machine and it now is in flood mode take side panel off and have a look and drain water away common fault
Sep 25, 2007 | Hoover 24 in. HD98E Built-in Dishwasher
Error
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Sep 03, 2007 | Hoover 24 in. HD98E Built-in Dishwasher
Hoover 24 in. HD98E Built-in Dishwasher Logo
933 people viewed this question
Top Hoover Dishwashers Experts
Philip Postlethwaite
Vitally Alcher
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
