Question about Plumbing
Our five year old Hansgrohe Ecostat Thermostatic Mixer for our shower no longer provides hot water under the same pressure that it did when it was new. I suspect scale build-up inside the thermoelement. Should I pull and replace the thermoelement or is there a way that I can clean it so that it will again give us pressurized hot water?
  • 119 Answers
You need to replace the part they are not serviceable
Posted on Nov 23, 2009
3 Suggested Answers
  • 50 Answers
SOURCE: hansgrohe concealed thermostatic mixer ref no 1537418
check for sediment in your valve body... sometimes sediment can build up particularly in hot water pipes and that can cause the pressure balancing function of the valve to limit total hot water and therefore you cant get it hot enough... here is a link to what I think is the proper valve and the instructions for installing it... you'll want to follow the instructions for flushing and pressure testing... if you have good pressure at the thermo body then you might try adjusting the hot limit stop also covered in the document linked below...
http://www.hansgrohe-usa.com/JP/hrgh0264.pdf
Hope theat helps...
Posted on Jan 05, 2009
  • 299 Answers
SOURCE: Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Posted on Apr 28, 2010
Testimonial: "Thank you so much for your help! Will try it out - your instructions are clear and sound do-able! "
Hansgrohe ecostat not at full water flow
The most likely cause for a decrease in flow on the Ecostat mixer is debris in the filter screens. Try removing the thermostatic cartridge and cleaning the filter screens on the the cartridge. Doing so will most likely resolve the low flow issue. If you need instructions feel free to contact me at Hansgrohe Tech. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to provide instructions for the Ecostat mixer.
Feb 04, 2013 | Plumbing
I have an iflo thermostatic bar shower mixer which no longer delivers hot water for the shower. Do i need a new Bar Mixer?
To get rid of this problem, you should consult with a professional. Apart from this, you can buy attractive and best quality shower mixer by visiting this site: showerenclosures
Jan 02, 2013 | iflo Home
How to clean Axor Terrano Showerpipe - hot water part of mixer seems blocked
There are filter screens on the thermostatic cartridge inside this unit. You will need to remove the thermostatic cartridge and clean the filter screens. If cleaning the thermostat cartridge does not resolve the issue you may need to replace the cartridge. If you need further assistance feel free to contact me at Hansgrohe Technical services. 1-800-334-0455. prees 2 for tech and ask for David Scarborough.
Aug 30, 2012 | Home
Hansgrohe shower thermostat: water is getting only Lukewarm. Hot water ok in sink and throughout rest of house.
The first thing to try is cleaning the filter screens on the thermostatic cartridge. Hansgrohe thermostat valves have filter screens to protect the element from debris or water deposits. If they begin to get clogged the valve will have a hard time regulating temperature.
Jul 28, 2012 | Home
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Sep 03, 2011 | Home
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Want to buy a thermostatic shower column which I believe was made in china--it looks beautiful but only has a 1 year warranty --sold only by Rona--will i have problems with it?
One year warranty is just good enough. Verify from Rona
if it will really honor the warranty. Nowadays, Chinese
product are now better than before. They learn it from the
American companies having facilities in China for lower
labor cost, and no strikes. You may buy the Thermostatic Shower.
Nov 22, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Hansgrohe concealed thermostatic mixer ref no 1537418
Hope theat helps...
Oct 25, 2008 | Hansgrohe Plumbing
Plumbing Logo
689 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
