How to format and reinstall windows xp
Just Put the XP CD in your CD Drive and restart your PC..you ll get a screen immediately after your PC restarts i.e. press any key to boot from CD..press any key in your keyboard...after some time.u ll get a screen showin whether new or upgrade required...click new...then u ll get a screen to setup in which drive..select a particular drive it ll format...follow the instructioons thereafter..It s just easy..
Please rate my suggestion
If you have a name-brand system, use the recovery CDs that may have been supplied or that you made when you first got the computer. (If you made the restore CDs. Many people ignore this step in setting up their new computers.) If you don't have any CDs you might be able to purchase them from the manufacturer.
Some name-brand systems have a recovery partition on the hard drive. Look for a message about system recovery when you start the computer. If the partition exists, follow the steps to boot from there. The recovery process will tell you what to do.
If the computer is a custom-built machine you'll need to reinstall XP from the original disc. All you have to do is put the XP installation CD into the drive, boot from there, then start the installation process. When the installation program tells you there is already an operating system installed you can have it format the partition already in use and install the system there. You'll need to use the XP product key from the sticker somewhere on your computer and activate it after installation is complete.
Start up a computer with
Windows XP, Vista, or Windows 7. Insert the SD card into an external memory
card reader or into the computer's built in card reader. If it the first time a
SD card has been inserted into the computer, Windows will recognize the SD card
and automatically install drivers to read the memory card.
Go to the computer
view by clicking on the windows start menu icon in the bottom right corner of
the computer. In Windows 7 and Vista click "Computer". In Windows XP
click "My Computer"
Right click on the
SD drive under the computer heading. A dialog box with different options for
the drive will appear. Click on "Format" to bring up the formatting
dialog box.
Select the type of
formatting (also known as file system format). In Windows XP or Vista there are
several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added
choice called exFAT formatting. This is an improved FAT formatting type with improved
meta data capabilities. Choose the formatting type, name if the drive if
desired, check or uncheck the "quick format" option, and press the
"Start" button. When the SD card format is
complete Windows will provide a notification.
If this answer helpful please vote me. Good luck. Thanks for using FixYa
