Arcam P7 intermittently drops centre channel - Audio Players & Recorders
  • jonmayled Apr 13, 2009
    Sorry - it didn't work - channel comes back if you turn the volume up.
    Top Expert:
  • Audio Player... Master
  • 77,499 Answers
Have you verified all the speaker connection are clean and tight? this is the usual cause
Posted on Apr 13, 2009
  • 749 Answers
Try to reset the devise, Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
Arcam repair
Maybe a firmware (that's the running program) problem I'd contact Arcam, if your Solo has a USB input they should be able to send you a firmware update which you can download to a USB stick and then upload to the Solo (instructions will be in the manual). If not your local Arcam dealer should be able to do it for you Arcam warranties are 3 to 5 years. Don't now if they'll edit this but also try AV Forums online. good luck
Aug 19, 2014 | Arcam Audio Players & Recorders
One channel cuts out
check for corrosion or dirt around the screws that hold that board in place. the screws provide ground at several different places on the pcb that are not otherwise connected. good luck
Jan 05, 2014 | NAD Audio Players & Recorders
We just purchased an LG, LED, LCD, TV and just realised that our existing Arcam AVR 100 does not have an optical out. Does this mean we need a new amp or are there alternative solutions? Many thanks.
Actually, it doesn't have ANY digital outputs. Just what do you require one for? Name specific models and functions when replying.
Do you think the TV NEEDS optical audio from the receiver? Maybe the TV could survive on just analog audio from the video source, while the GOOD audio goes to the ARCAM since the ARCAM is going to do the hard work of managing and driving the REAL speakers.
http://www.arcam.co.uk/_ugc/file/avr100e_manual.pdf
Feb 06, 2011 | Arcam AVR-100 Receiver
I have Arcam Receiver AVR 300. I bought it used a few months ago and the receiver had worked like a dream. Suddenly, for no apparent reason, there was no sound from the SAT channel/output where the...
Seems you set it to "Stereo Direct" mode. This is an analog only mode, while you are using a digital signal. You can change this with the mode button.
Press menu, on the main menu screen 1, scroll down to stereo direct. Turn this OFF.
This should solve your issue!
~KenjiFox
Jan 07, 2011 | Arcam AVR-200 Receiver
Using WRT120N, wireless connection drops intermittently. Problem is not the modem - connectivity is stable when ethernet cable is directly plugged into the computer. How do I resolve the intermittent...
I had a similar problem. I live in an apartment complex and there are many wireless networks all competing with one another. I changed the channel on my router to Channel 8, and have had no further problems. The default channels for most home routers are 1, 6,and 11. So, most users just power up their new routers and are up and running without realizing that there maybe 15 other routers in range on the same channel that are interfering with one another. You can download a trial version of PassMark Software's Wireless Mon application to see which channels are heavily used at your location. Then pick one that is ideally 2 channels away from any heavily used channel and set your router to this channel.
Aug 05, 2010 | Linksys WRT160N Wireless Router
How to hook up a computer sub to a hometheater amp
http://www.arcam.co.uk/_ugc/file/avr280e_manual.pdf
If you have the whole Z5500 package you could run the Arcam's optical- or coaxial digital audio output to the corresponding input on the Logitech.
But I'd be careful about letting BOTH the Arcam and the Logictech perform Digital Sound Processing on the sound. DSP's aren't meant to be stacked. My money says the Arcam is better in the DSP department than the Logitech.
If you have just the sub, run the Sub PRE out from the Arcam to the Sub/Center input (adapt it to 3.5 mm) on the Control Center and set the switch to "6 ch direct".
Mar 06, 2010 | Jensen JW250 Main / Stereo Speaker
My Arcam AVR300 is having issues with the digital optical input. Sound becomes distorted or shuts off completely at times. Sometimes, turning it off and on will resolve the issue, but other times, it...
The problem (Known to Arcam) is with the some diodes in the power supply to the DSP board. Over time they do not work properly and the power fluctuation makes the sound distort. They need replacing (only once to a higher spec) if you contact Arcam they can advise you.
Feb 15, 2010 | Arcam Audio Players & Recorders
Arcam avr 300 keeps switching off intermitently, and the red standby light flashes.
I wonder if anyone can help explain what the likely problem will be with my Arcam AV300 amp. Whilst watching TV for no particular reason an extremely loud (what i can only describe as feedback) sound comes out of my B & W speakers for approximately 3 seconds, then silence as the Arcam switches off, I’m then unable to switch it back on for a period of time, (this varies between 5minutes to a few hours) when it eventually switches back on everything seems to be working perfectly. This has happened quite a number of times although it’s intermittent & occurring every 1 - 6 weeks.
Sep 18, 2009 | Audio Players & Recorders
Arcam avr300 intermittent problems
I had this same problem with my Arcam AVR300. I ended up shipping mine to an Arcam repair center and they repaired it and shipped it back for under $200. The problems were cracked connection on the start relay and they replaced power supply diodes. Very well worth it and now I can enjoy it again!
Jun 30, 2008 | Arcam AVR-200 Receiver
49 people viewed this question
 Grubhead
Grubhead
