Question about Onkyo TX-SR500 Receiver
So how do you replace a fuse?
Unit shuts off immediately after turning on. Standby light blinks. No wires or cables attached. The unit is only plugged into the AC. Guess it's a fuse. No warranty. So how do I go about replacing the fuse?
  • tevans143 Dec 08, 2007
    same problem. went out all at once. fuse not blown.
    New Friend:
  • 99 Answers
Hmm. Tricky problem. It could be the main fuse blown and the standby power suply is only working. Worts case senerio is that one of your amp is faulty and the unit is in protection mode. If the fuse is dead then you are lucky, just get the cover open, remove the power before hand, and do a little search, Most of the time it will be in a glass tube ( glass cartridge type) rated at 250VAC with a nominal of around 5 to 7 amps rated current. U can check it with DMM in a continuity mode. If fuce blown replace with the same rating and it has to be slow blow type. Cheers
Posted on Sep 11, 2007
SOURCE:
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Sr576 standby light blinking
Most likely, you have DC Offset(a bad amplifier). The unit is shutting down to protect your speaker system, as well as protect the unit from any further damage. If you require more assistance, or would like to inquire about repairing your Onkyo, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jul 22, 2012 | Onkyo TX-SR576 7 Channels Receiver
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
I was watching the news and it shut off on its own and will not turn back on. What do i need to check?
If you include how many times the standby light flashes, that will give a fault location. Not to worry, here is a list.
Hope this helps.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Jan 23, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Trips and switches off
Hello Fixya customer,
Thank you for your question.
The best way to fully isolate the fault is to disconnect all the speaker wires, and verify that there are no strands of wire shorting between the speaker terminals on the rear of the unit.
Turn the volume all the way down, full CCW, and if it goes into shut down with the STBY light blinking then there is a fault in one of the amplifier's.
Thank you for using Fixya, and if I can be of further assistance please ask.
May 01, 2010 | Onkyo TX-SR706 Receiver
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Standby light blinks 6 times
It is fuse issue again. Go to this website and you should have solution or ask for one:
http://www.avsforum.com/avs-vb/showthread.php?t=507602
Dec 18, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
i replaced the thermal fuse on my kdf-55wf655 and still have the 6 blinking lights,,any other ideas.
Nov 03, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
i had the same problem to, i replaced the thermal fuse and everything was back to normal. Be careful if you are a gamer because both times this has happened i was playing my xbox
Nov 03, 2007 | Televison & Video
Standby light blinking -unit won't stay on
When it is on, does any audio come out of the speakers? If so, you may have a problem in the protection circuits. If no audio is heard, I would first check the speaker wires to make sure there are no strands shorting across the terminals, and that you have the it selected to output audio to the speakers -- Now also be sure to check the various inputs, for instance if it has a FM receiver, select that and see if any audio comes out then as well. I don't know what the cable guy could do other than knock loose a wire or change connections on you.
Jan 13, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Receiver Logo
347 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
