Question about Maytag MZD2766GES Side by Side Refrigerator
I need to know where the adaptive control defrost board is located in the fridge
  • Maytag Master
  • 3,361 Answers
In the top right rear corner of the control panel.
What is your problem?
BTW your fridge is on recall from Maytag.
Posted on Apr 29, 2009
3 Suggested Answers
hiltonjug
  • 612 Answers
SOURCE: maytag MZD2665HEW ADC replacement
You will find the defrost control board inside the panel that contains the two turn knobs where you control the temp inside both compartments. It's inside your fresh food section of your unit. Pull the two knobs off, take the screw out of the side and remove plastic piece. Between the two temp controls there is a square box. The board is located inside the box. Take box apart and replace board.
If you would like a parts blowup of the unit, go to www.partselect.com and enter your model number. Select the Control panel to the left. This will give you a blowup of the parts.
Please rate solution
Posted on Sep 10, 2009
Testimonial: "Told me exactly what I needed to know to fix my fridge. Many thanks!!!!!"
SOURCE: I need to replace the adaptive Defrost Control
Its Located in the top right inside corner of the refrigerator section near the back wall & to the right of the water filter.Its tough to get out but only takes about 10 minutes to replace the part
Posted on Nov 19, 2009
Testimonial: "great help"
Where are the refrigerator fuses located for a Maytag msd2652keb
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are no fuses in refrigerators. Individual component failure acts a fuse.
You are locked into defrost.
PART NUMBER: 67004704 - Cost: $116.00
This is located in the upper right inside your control box.
This replacement adaptive defrost control board (part number 67004704) fits several models of side-by-side refrigerators. The adaptive defrost control board starts and stops defrost cycles as the temperature of the evaporator rises and falls instead of on a set schedule.
Shut off the circuit breaker for the refrigerator before beginning this repair. Also make sure you're well grounded (Rub hands on bare metal), because electronic components can be damaged by discharges of static electricity. The board installs behind the digital display in the control panel. Procedures for removing the existing adaptive defrost control board and installing the new one vary among models.
Dec 07, 2014 | Maytag Refrigerators
We have Jenn Air Built In Ref Model# JS48SEFXDA. We had the Power Supply Circuit part# AP4076255 replaced last year. We had a power outage 3 days ago. The fridge and freezer just quit cooling today. The...
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. Maytag/Jenn Air has one version, see diagram...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle.
Jul 24, 2011 | Jenn-Air Refrigerators
The freezer is frosted up and the refridgerator is not getting cold. I have vacuumed out the coils.
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. To put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle
Nov 27, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
The freezer & refrigerator will either turn on & cool and or freeze but won't shut off. Or they will not come on at all and get warm or thaw.
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle.
Nov 18, 2010 | Maytag Refrigerators
Coil frozen over, freezer not freezing and fridge inefficient. msd2758gew
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. has one version..to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. .
Nov 01, 2010 | Maytag MSD2758GEB Side by Side...
I have a Estate bran fridge and it keeps defrosting every two days it's a new fridge what could be the problem
HI. This will occur if your defrost module is malfunctioning. There are two types of defrost controllers. The first will be an adaptive control board. This will be located in the control housing, just above the heat shield, in the upper right had side. Older models will have a standard defrost timer mechanism. When these devices are malfunctioning, You will notice erratic defrosting cycles. I recommend to inspect the module, to confirm that it is set correctly, and is operating.
If equipped,The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor. It will have an adjustable dial. make sure it is set to a proper defrost interval.
NOTE_ If your unit is equipped with an adaptive defrost control board, and the defrost cycle is erratic, this will require you to replace the board. this type of defrost control module is not repairable.
Nov 10, 2009 | Refrigerators
Maytag MZD2665HEW ADC replacement
Sep 10, 2009 | Refrigerators
HOTPOINT FRIDGE - COILS FROSTING UP
as you know your unit is not going through defrost cycle. you need to replace either the control board, defrost heater and or defrost thermostat. ge is known for their defrost heaters going out.
Jun 24, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Amana Fridge that won't keep cooling.
Inside your refrigerator fresh food compartment and behind the control panel is a Adaptive Defrost Board this could be the problem or the start relay and start capacitor located on the compressor. I would unplug and examine the defrost board first to see if it looks abnormal. Second I would replace the parts mentioned at the compressor if the Adaptive Defrost Board looks ok. Below is a link that you enter your model number in the model parts search feature. The part number for the Adaptive Defrost is 611005988
Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 28, 2009 | Amana DRSE663B Side by Side Refrigerator
Frig side not working on Maytag MZD2766GEW
freezer not defrosting. probably adaptive defrost board in fridge.
take panel off freezer (inside, back panel). if all frozen, can defrost with blow dryer. best to remove fridge control panel (inside, top of fidge). access adaptive defrost board, jump test to f1 (i think) next to test. this should initialize defrost mode. buy new board.
May 23, 2009 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
236 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
