Question about Dewalt DW077KI 18 Volt Self Leveling Cordless Rotary Laser Kit
DW077 laser level. Works perfectly then after a while stops and the power light starts to flash and the unit begins to beep. Can you tell me what the problem is? It is a new battery and fully charged. Many thanks Gordon
3 Suggested Answers
protek480
  • 1714 Answers
SOURCE: i have a dewalt DW005 24V hammer/plus drill i am
The battery has probably lost it's ability to receive a charge. Is it old? Check the output of charger, should be around 26 volts DC at the output jack.
Posted on Jun 26, 2009
moorah1
  • 181 Answers
SOURCE: no power to the radio but charger works
could be few issues, as of cracked boards, if you dropped it few times, or short in output/ internal power distribution. must be open by tech and troubleshoot properly. Definitely, not a do it yourself job.
Sorry.
Posted on Jan 27, 2010
Beginning of cold cycle water temp lights flash and beep machine stops. Sometimes when water level set to high only half fills ??
SOUNDS LIKE U MAY HAVE AN ISSUE WITH EITHER UR WATER PRESSURE SWITCH OR UR WATER INLET VALVE/
U FAILED TO MENTION IF IT WORKS OK IN HOT WATER? IF SO THEN CHECK UR INLET VALVE OUT THE COILS MAY HAVE GONE BAD ON THE COLD WATER
May 16, 2015 | Washing Machines
What is the appropriate fix for front load dryer that turns on and begins to run, but at any moment it stops, beeps over and over and lights all flash. The only way to stop the beeping/flashing is to
Thanks for the make and model of dryer. It is likely the thermistor is faulty. This tells the dryer how hot it is getting. If dryer is ok to start with (cold) and then starts doing strange things once it heats up, then this is what one would suspect. The control board problem would show up in strange ways including not being able to start the drying cycle. For location of thermistor see the drawing on this site. The model may not be exactly same as yours but gives an idea.
Items 33 and 36 in diagram 1. Frigidaire Washer LEQ2152EE1 Parts List
Sep 10, 2014 | Dryers
Need to know how to calibrate dw077 laser
Hold down the ( V ) button while powering the unit on. THe puts the unit in cal mode for the Y axis. Hold down the up button while powering on the unit, this puts it in cal mode for the X axis. that is as far as I have gotten.
Paul
Apr 01, 2011 | Dewalt DW077KD T Self Leveling Rotary...
Red light will not stop flashing only just started, less than a year old
When the tool is level, the lasers will stop flashing, but check out the batteries too, because if they're weak, the tool will not level, and the lights will continue to flash .
Dec 20, 2010 | Robotoolz 3 - Beam Level and Plumb Laser,...
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Dewalt DW077KI 18 Volt Self Leveling Cordless Rotary Laser Kit Logo
155 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
