Question about Brother DCP-340CW All-In-One InkJet Printer
Wireless network I've set my priter to my wireless network using a router but when i run the software to set upthe printer on my laptop it doesnt pick upthe printer so unable to select and carry on set up
  • 832 Answers
See here: http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000400/000057/faq000457_001.html?reg=eu&c=gb&lang=en&prod=dcp340cw2_eu
Posted on Sep 14, 2007
SOURCE:
I have cannon D1150, my laptop need connect to the printer through wireless router. What is the procedure?
It's easiest if you can physically connect the printer to the router with an ethernet cable, then add a printer to the laptop, Network, locate and install.
But if it isn't near the router, you need to use the options on the printer settings to connect wirelessly to the right router, then add the network printer. Running the software on the laptop should work and is probably the preferred method so all required drivers and software is available, once the printer is on the router.
Jan 27, 2018 | The Computers & Internet
I have a Canon MP495 inkjet printer. I had a linksys wireless router and changed to a netgear wireless router. Since the change I am not able to print to the priter over the wireless network. Before the...
the printer must see the router, follow manuf. instructions, ( from printer especially. ( just a minor communications issue. al;so check and make sure both units are plugged in and powered up
Nov 13, 2017 | Canon Office Equipment & Supplies
Hello, I have a brother MFC-490CW mult-function printer (wireless) and I am having trouble setting up the wireless feature so my laptop can print to it via through my home network (Linksys wireless...
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Nov 25, 2010 | Brother MFC 490cw Color Inkjet...
Not pickin up netwark
depends on your laptop have you checked if the wireless card on your system is turned on? check the switch as well most laptops have 2 switches a phsical switch to turn the wireless on and off and a switch that you computer manufacturer has using the function ket FN+another key that your laptop has set to turn wireless on in lenovo it is FN+F5 for a dell it is FN+F8 if can't tell call your computer manufacturer ^_^
Is this for a laptop or a desktop? is this a wireless USB dongle or a wireless card? Belkin has a router and a USB wireless card.
Jun 05, 2010 | Belkin (F5D6051) 802.11b Wireless Adapter
Get my laptop to pick up the zoom router
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here
for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 16, 2010 | Zoom (5590-00-03) Wireless Router (G66115)
Network problem with Aficio 1515f
Sounds like you have a wireless router, but are (for some reason) plugging your laptop into it, and if it's not wireless, you should return it and get a wireless one for about the same money, that will let you use your laptop from anywhere, and the setup is often easier, as it can usually all be done via the Installation CD. You can also still plug the Aficio 1515 into the router and print wirelessly to it from your laptop, once you have it configured.
Next, the Aficio 1515 printer feature included a standard usb port, so I find this a little strange.
You can download the manuals here:
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
The 'network settings' guide will be most helpful. The two things you primarily need to be concerned with are the "IP address", and "subnet mask". Do not use "Auto", but rather set them manually, and then configure the printer driver
If you don't have a basic understanding of IP addresses, and network printing, then you'll really need some help to complete the setup
Mar 02, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
I have just lost my connection with my wireless. Tells me it has been disconnected however I am able to pick it up with my other laptop?
Delete the wireless profile out of your computer. Click on the wireless icon in the lower right hand corner of the screen. Right click and choose View Available wireless networks. Click change the order of preferred networks. In the preferred networks area click on the wireless network and click remove. Now reboot the computer or disable wireless and enable wireless. Once that is complete try and connect to your network. If this doesnt work try moving closer to the wireless router to see if that solves the issues. If you are using a third party software to connect to the wireless AP. Make sure you have the Use Windows to configure my wireless network settings unchecked in the Wireless network connection Properties window I had you open earlier to delete the profile in. If you are using a third party software like cisco, I would suggest using Windows to manage your connects.
Thanks,
ArmyMason
Feb 20, 2009 | Linksys Wireless-G Broadband Router
Laptop not seeing my wireless router
Try to manually "Add device to network" by using the wireless setup wizard. Check to see if the Wireless Zero Configuration service is "Running" before trying to add device. Yuo may also want to disable IPv6 in vista tcp/ip properties page.
Jul 17, 2008 | Linksys Wireless-G Broadband Router
Samsung 3160fn network question
You have to have the software set up on the laptop to be able to print from it. Also when you install the software make sure the laptop is hardwired to the router. I have found that if I try to set it wirelessly it won't work. I set it up hardwired to the router then it found it wirelessly. So make it short. Set up the printer on your laptop as though the laptop is actually a desktop. Then it will be able to find the printer wirelessly.
Also make sure that when you check the Network settings on the printer you have the same TCP/IP address for the printer in the PC and Laptops. I posted a long explanation on another post in this forum. You can take a look and find as a solution to someones network problem. The way I do it is to set up the router on the computer first. Hook up the internet to the router. Then set up all the other PCs on the router. Then hook up the printer to the router and turn it on. Then run the installation software for the Samsung and make sure you tell it the printer is set up on a network. See if the software can automatically detect the printer (it should). Pick your printer from the list of found devices and install it. It should work fine then. Also make sure that the Windows firewall is turned off when you do that or have it set to allow local network traffic. Good luck.
Mar 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Problem in wireless connection.
ok First Didnt say what operating systems you were running 2Have you updated from windows SP2 let me Know ttech
Aug 01, 2007 | HP Photosmart C6100 All-In-One Printer
Brother DCP-340CW All-In-One InkJet Printer Logo
100 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
