Question about Philips Magnavox 42MF521D/37 Television
Phillips Magnavox Model 20MT1331/17: It shuts off
Phillips Magnavox Model 20MT1331/17: It shuts almost immediately in repeated attempts to turn it on (this can go on for 1/2 to 1 hour, sometimes longer). Rarely, it will stay on, but then at some point, it suddenly shuts off again. The settings indicate that no sleep setting or other timer is active. I've disconnected it from the cable box to be sure the problem is the TV, and the TV still has the same problem.
  • a_leclaire Apr 13, 2009
    Thank you for trying to help, but I don't know what you mean???
  • Philips Master
  • 5,568 Answers
The poster, Jim K, is probably in possession of at least a layout of the power supply and the 'location' is likely derived from a grid used to physically find parts on a board.
220 uF is a common value for an electrolytic capacitor and the 200V is the rated sustained DC voltage it can tolerate.
The 130 volts could be caused by a capacitor that is failing and not smoothing the rectified voltage as it should.
In other words, you kind of need a tech.
Posted on Apr 14, 2009
    Problem Solver:
  • 4 Answers
Location 2504 220uf 200 V Open B Plus Was Low 130 Volts.
Posted on Apr 13, 2009
Auto repeat got turned on somehow can not find how to remove it and phillips will not assist without recept can you help
Open your options menu while a disc is playing. I believe that's the only way to change such settings is to be actually using it. Although I thought there was a Repeat button on the remote too.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Philips Magnavox DVD/VCR Dual Player
The tv will not turn on
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Sep 28, 2009 | Samsung LN-T4053H 40 in. LCD Television
Stupid tv!
Sounds power supply board is bad in your TV and most probably replacement of all electrolytic capacitors in power supply board will solve the issue.
Take TV to local TV repair shop for repair.
Thanks.
Aug 30, 2009 | Akai LCT3201TD 32 in. LCD Television
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture or sound
Contact us at www.TvRepairKits.com. We are working on solving this problem as we speak.
Nov 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 42MF521D/37 Television Logo
646 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
