Question about Whirlpool ET8CHEXSQ Dryer
Dryer won't rotate stuck on fluff
I have a whirpool gas dryer, the basket stopped spinning when door is closed. it gets hot but won't rotate... I had one repair guy to look at it and was told that the dryer was stuck on fluff and suggested I buy another... please help
  • 490 Answers
One of two things has happened the belt is broken or the electric motor has failed
Posted on Apr 13, 2009
The dryer was drying, and suddenly stopped and control panel says call technician. Then says door open, won`t start after unplugging to reset it. The inside light stopped working at that time.
It may have overheated. Wait a couple of hours and try again. If it still doesn't work you will need an engineer to diagnose the problem. As it went out during a cycle it could be high limit thermostat or high limit cut out. Both are available on eBay and Amazon. Those parts fail if the dryer gets too hot caused by bad airflow, clogged filters, exhaust pipe or stuck vent slats outside.
Mar 16, 2016 | Frigidaire Fasg7073Lw 7.0 Cu Ft Steam Gas...
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
My Washer Baskets is leaning to one side when washing and spinning
Hello penpoint1959 - The tub is stabilized in the center with multiple springs which attach to the base of the washing machine and the frame of the tub. If one of the spring(s) is loose or broken, this may result in the tub being off center. Other possibilities are, the unit is not level and the load of clothing is not balance evenly in the tub. I personally first verify that the unit is level and the unit is being loaded evenly. If correct, and if I was in your position I would contacting a certified technician to move forward accurately and to assist with the repairs.
Feb 17, 2013 | Frigidaire FEX831CS Top Load Stacked...
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My whirpool dryer won't spin
It can be due to few reasons and so you can check on them.
1. Check the main power line, trace to the main control switch and its output. If not the switch is faulty.
2. Check the working of the motor, check the capacitor to the motor.
3. Check manually if the drive is free and is not jammed or struck up. If so you will need to overhaul the mechanism.
4. Check the door switch is the switch is faulty the motor will not be turned on.
Sep 06, 2011 | Kitchen Appliances - Others
Have a DLEX5101V dryer... It won't stop spinning after the timer ends - as long as the door closed it keeps spinning.
if you can get access to your main control board be hind panel. unplug dryer then tap the control board a few times. you could have a stuck relay. plug back in and try it. may fix you problem short term.
Aug 17, 2011 | LG DLEX5101V Electric Dryer
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
Will not spin, therefore will not drain
Hey Joe,
Let’s check to see if the wash basket will rotate CCW in Spin Only Cycle with no clothes in the wash basket
1. Open the lid and rotate the wash basket by hand Counter Clockwise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clockwise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 3. (See page 33 of the Service Manual for putty knife insertion point).
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it should begin to rotate CCW does it?. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction. If the basket does spin CCW and the tumblers are rotating then you have a broken clutch spring. Let do those checks and observations and see what the next troubleshooting steps will be. Rich
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirpool dryer wont run
inside light on when door is closed??? that sounds like a bad door switch. it doesnt recognize the door shut so it wont start, replace the door switch
Mar 29, 2008 | Dryers
Whirlpool ET8CHEXSQ Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
