Question about Ovens
Not mantaning temp
Ge oven not mantaning temp
  • 3 Answers
Need a bit more info, gas or electric, fanned or conventional. (engineer with 15 years experience)
Posted on Apr 13, 2009
Ge true temp oven
Sometimes you will have to pull the oven out to get access to the connector for the sensor. It could be jammed in the back or the hole is just too small to pull the connector through the wall.
Feb 15, 2014 | Ovens
Ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
Ge oven temp not correct after clean cycle
What are you cooking pizza. When you get at the high extreme most oven controls are not as accurate and have a wider differential. I assume the measurements are taken without opening the oven.
Dec 03, 2009 | GE Profile JTP56 Electric Double Oven
Convection oven burns most things GE electric. Is there some way to turn off the fan
Don't press the convection bake key before entering your oven temp,just push the bake key first then set temp and then start.If this doesn't help GE help center is awesome @ 1-800-626-2000
Nov 22, 2009 | GE Ovens
My GE oven heating element heats red hot no matter what temp I put the oven on
Something is probobly wrong with the thermostat, it gets hot to warm up, but should lessen as it reaches your desired temp. If the thermostat is bad it will just keep going.
Nov 20, 2009 | GE Profile JTP18 Electric Single Oven
GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
Sep 10, 2009 | GE Profile JTP56 Electric Double Oven
GE Oven MODEL J KP27WOP2 WG - WILL NOT HOLD TEMP
You can re-calibrate the oven as follows;
press BAKE pad.
select temp of 500 degress or more.
immediately PRESS and HOLD the BAKE pad until "00" appears.
Then press the + or _ pad to adjust temp up or down 5 degrees at a time.
When fimished press the Clear/Off pad.
Mar 15, 2009 | GE JTP15 Electric Single Oven
Ge tru temp
My GE oven was doing about the same thing and i replaced the glow bar and that solved my problem.
Jan 07, 2009 | GE JGRP17 Gas Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
