Question about Canon BubbleJet i560 InkJet Printer
No power My Canon i560 won't power up any more. The power supply seems to be working and I can't find any loose cables or burnt-through parts .
  • 5 more comments
  • Anonymous Nov 01, 2007
    my printer will power off during a print job and not be able to be turned on again
  • DeadinWater Nov 10, 2007
    No power - checked all cables, plugged into different power source.
  • Anonymous Nov 12, 2007
    No power to i560s printer, problem with power module on printer. Have to get module from canon.
  • basee Nov 12, 2007
    no power
  • Anonymous Nov 14, 2007
    Green light turns on for a second, then turns off. Tested power supply get 11.5V and !3.4V. Numbers stamped on supply say output should be 24V and 27V. Bought new power supply. It also tests 11.5V and 13.4V. Either both power supplies are bad or does the printer circuit somehow switch the power supply to a higher voltage. Does anyone know what the "cont" wire coming out of the power supply is for?
  • richie1636 Nov 17, 2007
    Mines been working fine for 2 years and then the other day went to turn it on no power. I've checked the fuses and cables nothing.
  • GAIL BUSCH Dec 12, 2007
    Amazing so many people with the same problem including me. I'll try cleaning the printhead.
I had the same problem just this morning, 14 Dec 2008, after some power interruptions to my area the previous night. I changed the fuse in the mains plug to no avail. I the unplugged the thing completely with the intention of throwing it away, but I turned it upside down to look for the power supply, prodded, poked and shook it a bit just for fun. I plugged it in again and lo and behold it now works!
Not very scientific (there may be loose connections somewhere) but I hope it may help.
Posted on Dec 14, 2008
Just took the cover off and cleaned the printerhead. The light came on for about 5 mins. So you could be right. Just checked for replacement head and they cost over £40 might aswell bin it and buy a ip4500 for an extra £20.
Posted on Nov 19, 2007
Re: my 11/14/07 post: Apparently, the lower voltages are correct for the power supply when not connected to the printer. Removal and reinstallation of the print head resulted in the printer powering up. I had to remove the cover since the print head was off to the side. It worked for a day but now I get a print head error. I suspect that the print head was the problem all along. But I have to decide if I want to spend more money on a new print head to find out.
Mine did the exact same thing for apparent no reason. I have checked all wires and plugs. Please help!
Posted on Sep 20, 2007
Why doesn't it turn on?
Check all wires and connections. If u confirm power reaching the innards of unit then there is an issue with the power supply of printer.
Mar 12, 2016 | Canon Pixma MP500 All-In-One InkJet...
Amber and green light keep flashing back and forth, not printing. I tried rebooting, nothing happens
Switch off the printer and disconnect from the power supply. Leave for 10 minutes and then try powering up again from cold. If you are still getting flashing lights please count the number of each flash and repost
Mar 01, 2011 | Canon BubbleJet i560 InkJet Printer
Canon i560 yellow light blinks 5 times. How do I clear it and have good printer again?
This is a printhead/cartridge error.
First try to reset the computer:
Resetting the PrinterBy resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur.Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
If that doesn't work try to reseat the printhead.
Feb 20, 2011 | Canon BubbleJet i560 InkJet Printer
I560 will not power up
The Canon printer has a power supply problem, I have found that when the fuse goes, it usually indicates shorted diodes and a filter capacitor, It will need to be dis-assembled for service.
Jan 19, 2011 | Canon BubbleJet i560 InkJet Printer
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
Is there a solvent available to unplug the print heads of a Canon i560 printer
Goof off will do the trick. Remember after you can fool around with it, it won`t work again. You just have to replace them.
Mar 17, 2010 | Canon BubbleJet i560 InkJet Printer
I have a home network using a desktop Dell 3000 series computer and want to add a Sony Vaio laptop. My network works ok but I cannot share my Canon i560 printer. Any solutions?
Sony Vaio is operating on Windows 7 and Canon does not supply drivers for my i560 Canon printer. I was able to download a suitable driver from another source. I have since bought a new Epson printer/scanner at a good discount which works well on the Vaio laptop.
Nov 23, 2009 | Canon BubbleJet i560 InkJet Printer
Our i560 suddenly will no longer turn on
Sure it is, try removing the inks and then the printhead. If it will power up with them out, you need a new printhead. Don't put the old one back in as you could fry the logic pcb. The printhead part number is stamped on the side.
Nov 03, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 printer will not turn on, despite power. Is there a reset bntton or combination that may make it possible or is it a short life product?
Have you checked the fuse on the power cable? Have you tried another power outlet and changed the power cable?
If you have the chances are the power supply unit in the printer is faulty. It may have an onboard fuse that has blown or maybe the PSU is fried.
Jul 16, 2008 | Canon Office Equipment & Supplies
Canon BubbleJet i560 InkJet Printer Logo
226 people viewed this question
old marine
old marine
