Stop Blowning Heat
I have a Fedders A/C- Heat Window unit and it stop blowing heat. Checked continuity and found some sort of resistor located near heater element that seems to be bad. Not sure if it's a resistor and the schematic doesn't show it to be there.
    Guru:
  • 588 Answers
It's a fusible link, and if the temperature gets to hot it opens up.
If you disconnect any wires to it and ohm it out and you don't get any continuity then it's bad and needs replaced.
Posted on Aug 02, 2009
Have a 2009 Nissan Quest I can't turn the heat off. Just stays on a high level of blowing out heat .
If you have a fan that has different speed settings (1234, or low med high etc) and the only one that works is high - then the blower resistor pack has failed. If you have a climate control unit (where you just pick a temp you want) then the fan is controlled by the heating system and it sets fan speed. If you have climate control style try lowering the temp to a lower setting (current temp in vehicle) and see if fan slows down. If not then climate control unit or fan resistor bad. If dial type and you get nothing on lower settings (only high works like mentioned above) you need to change blower resistor. It is located under dash near the fan itself. Look for small unit bolted in duct near fan with wire plug going to it.
Feb 23, 2015 | Nissan Cars & Trucks
I have a fedders window unit 220v 18000btu. The ac side works great but when swapped to heat it just blows cool no heat. The filter light starts flashing as well in heat mode
Those window units usually have a strip heat kit that supplies the heat. You might want to have a technician open up and check heating circuit.
Oct 31, 2014 | Heating & Cooling
Why does the air conditioning unit stop blowing after second setting on 1996 Dodge Dakota Sport truck?
Blower switch is bad, or the blower's speed control resistor is bad, or you have a poor connection in a connector between the switch and the blower.
Jul 29, 2014 | Air Conditioning and Heat for Dodge Ram...
Window A/C unit .. fan will blow... sometimes it blows cool air and sometimes it's warm air. ???
Try adjusting the thermostat to cool or heat position. Your a/c is good for summer and winter operation.
Sep 01, 2011 | Fedders A6X05F2D Air Conditioner
My 2001 520i BMW 2001 model has stopped blowing heat/ac. It was working fine when I last drove it for about 100 miles. But then the next day it didn't work at all. Even front and side windows demisters...
I had the same problem with my 325 coupe. I had no blowing air and the only heat i got was coming from the engine. I got an auto electrician to look at this and he found it was the heater motor resistor that was broke. I got mine from BMW and cost me about £120.00. I hope you can get it sorted.
Jan 01, 2011 | 2001 BMW 5 Series
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
Gas Dryer does not continue to heat.
Check the Following to address this issue--
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 02, 2009 | Whirlpool Dryers
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Heats for 15 - 20 mins then blows cool air
If the outdoor unit is in defrost mode the compressor will be running but the outdoor fan will not. You may even see some steam rising from the coils. This mode is to prevent frost or ice build up on the outdoor coil. Essentially it goes into cooling mode w/o the outdoor fan running.
Mar 05, 2009 | Goodman GPC1342H21A Air Conditioner
Heater stop blowing
Notorious for the blower motor resistor failing from moisture build up.Located above passengers foot well on bottom, forward side of HVAC box. NOT real fun to R&R! Good Luck.
Feb 08, 2009 | 2004 Pontiac Grand Prix
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
