Question about Neff 24 in. S5543X2 Built-in Dishwasher
I have a Matsui MS160SLI dishwasher it keeps on draining and will not fill with water. I have tried everything in the manual but nothing works. Help.
  • Neff Master
  • 19,396 Answers
If the cycle does not stop draining that is usually because of a faulty water level switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Check if the floating sensor is stuck or faulty.
Some machine may use a membrane switch instead of a floater.
Posted on May 21, 2009
Water level stays to high, everything else is working fine. just does not go down low enough and next cycle pushed water out over the lip at the front
two issues.
the first is a retricted drain . either the hose is kinked or a blockage at the drain valve, or where the hose joins the sink plumbing. disconnect it from the plumbing and let it run into a bucket to observe the flow.
The second is, the float protecting an over fill is not shutting off power to the fill solenoids in the event of over filling. Try raising the front feet and keeping the rear as low as possible to bias the water to the rear of the tank.
Dec 29, 2013 | Hobart SR24C-4 Undercounter Dishwasher
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Even though dishes are rinsed, the drain filter is always filled with dirty water. dishes have soap reisdue and/or are not clean. we had a plumber look at it and he said the hoses are not kinked -...
It looks the main drain is choked. Give a try by keeping the machine discharge hose in a big bucket or tub and run the machine. Watch-out. the bucket should not overflow and soil your floor.
If you find every thing is alright check your main drain pipe.
May 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Running but not cleaning
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Matsui dishwasher wont fill up with water
check your inlet filter at the tap source and behind the machine where the filler pipe enters. They changed some pipes in our street and fine sand filled our micro filters to the dishwasher.
Jan 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Matsui MF145 beeping continuously
You might want to check the salt and rinse levels on your dishwasher.
Ours was doing the exact same thing and we refilled the dishwasher salt and it worked again. Unscrew the plastic thing on the bottom of the dishwasher and fill it up with about 1 kilo of dishwasher salt, water will flow out when you do this and you can put at least 2 kilos in.
Hope that helps xxx
Apr 02, 2008 | Dishwashers
Neff 24 in. S5543X2 Built-in Dishwasher Logo
399 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
