Question about Frymaster Dean MJH50-SD Deep Fryer
Fryer burning really yellow flames even after everything has been adjusted correctly. Has strong smell when burning.
  • Anonymous Apr 17, 2009
    burning yellow even after changing air shutter on buners-natural gas fryer
  • 640 Answers
Is this a propane fryer?
Posted on Apr 13, 2009
We have a PitCo fryer that has started sooting everything up above it such as the vent hood. By the end of the day things above it are really black
If it is burning with a sooty flame it means there is not enough air being burned with the propane. You can check around where the jet enters the burner tube, but my advice is to get it professionally serviced by a registered gas fitter, as as well as soot it is giving off carbon monoxide.
Jun 20, 2017 | The Kitchen Appliances - Others
My lpg fryer IFS40 burns yellow flame and on the recent inspection tech supposedly found corroded heat exchanger. The fryer is only half a year old and still under warranty but the imperial only offer
The heat exchanger might be a result of the yellow flame but not the cause of it burning yellow. I would guess it is the amount of air being mixed with the gas. Most burners have a slotted metal air mixture ring on the front of the burner near the brass orfice, you are calling a jet. There is a locking screw to release the ring so it can turn to adjust the amount of air being mixed with the gas. If this doesn't fix the yellow flame it could be a gas pressure problem that could be the external regular in the gas line. Not sure if you are talking about the pilot flame or the burner flame or both? A tech should know how to adjust the air mixture.
Oct 15, 2014 | Imperial IFS40 Deep Fryer
My flame is burning yellow and there is no pressure. Can you tell me what I can check?
The burner is blocked need cleaning/ the air ports to the burner are blocked lack of air causing yellow flame and soot
Needs a service asap.
May 15, 2012 | Imperial IFS40 Deep Fryer
WE HAVE A NUMBER OF LPG IMPERIAL IFS40 FRYERS WITH A VERY LARGE FLAME ESSESIVE FOR THE UNIT FLAMES BURNS AND EXTENDS AT THE BACK OF THE FRYER INTO THE FLUE . WE HAVE CHECKED THE CORRECT INJECTOR , CORRECT...
check the burner orifice and gas valve spring kit if it is suited for propane use.remove carbon build up inside the fire tubes.check also if the gas pressure is correct.
Mar 11, 2011 | Imperial IFS40 Deep Fryer
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
My pitco 35 c the flame is burning yellow and not going inside the very wall i thought it might be the regulator pressure on the fryer on the back side
Low gas pressure will produce low flame quality (yellow flame).
Check and remove any dirt or soot on burner holes, and orifice
Burner flame not going inside the fire tube could be due to soot or carbon build up inside the fire tube blocking the flame path, check the inside of the fire tube, if considerable amount of soot is seen, better have them removed.
Yellow flame will cause a lot of problem on fryers if not corrected as soon as possible.
If you have doubt on your gas regulator, better have a qualified service technician to check it.
Sep 02, 2010 | Pitco Frialator 35CS Deep Fryer
I USE THE FRYER WITH PROPAN GAS THE FIRE IS YELLOW AND ITS SMOKING EVEV IF THE PROPAN IS FULL
You need to adjust your "Jet" and or mixture control if there is one, the Air/fuel "Mix" isn't correct. It should burn a nice "Blue".
Mar 11, 2010 | Pitco Frialator SG14 Deep Fryer
Deep shut down
your themostat is either bad or your hi limit is bad if the oil gets too hot the hi limit will shut everything down for safety or if the oil temp is good it is the limit control shutting everything down when if should not first thing to check to see if the in the tank matches up to the knob if so change the hi limit it if not change the thermostat
Nov 13, 2008 | Cecilware FMS-40 Deep Fryer
Long recovery time during busy times have a sg 14s fryer
Make sure you have a nice blue flame in burner the more yellow that it is the less heat it put out. To adjust the flame there are air control slides on the burners there the flame comes out. Open or close them to get the proper setting. You will see the flame go yellow and blue, the bluer the better. The gas pressure could be off which you have to check with a manometer 3 lbs per water column on natural gas and 11 lbs. on l.p. gas. Check the gas valve inlet screen for dirt. If the burner system is operating properly then you have a bad or dirty t-stat
Sep 26, 2008 | Pitco Frialator SG14 Deep Fryer
Frymaster Dean MJH50-SD Deep Fryer Logo
188 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
