Question about Bosch Dishwashers
Where can I get the instruction manual for a Bosch Classixx Dishwasher SGS53C12UK? I have bought a second hand dishwasher that has only been used for 6 months. The programme works fine but when I go to use it again - check water shows on the display. I have to tilt the machine back as water is stored at the base of the machine, surely this is not normal? It there a simple solution to this or alot of cost involved with a new part? Any help would be much appreciated. Thank you.
  • 641 Answers
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Posted on Jun 27, 2006
  • 1462 Answers
SOURCE: bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Posted on Mar 20, 2007
  • 213 Answers
SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Posted on Nov 20, 2007
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
Dissolu
  • 221 Answers
SOURCE: Bosch Classixx6 washing machine. Which side for detergent?
Left one.
Posted on May 12, 2009
Bosch Classixx Dishwasher -check water light keeps coming on
thanks i empied my dish wisher old water then it word again thanks Neil Spink
Apr 14, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Nov 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher with these numbers inside door
i solved the problem by going to bosch uk website and one of the numbers came up when i went to download instruction manual
so that solved problem. thanks for your help.
Sep 17, 2009 | Bosch 24 in. SGS43C12 Classixx...
I have a bosch dishwasher that wont drain
Question! Did u buy this from Bosch? If you did not, then your contract is with the Store you bought it from and NOT Bosch and you should be contacting them and they should sort the problem.
A blockage, can sometimes be solved by putting one of those diswasher cleaning tabs in the machine a couple of times and see if that sorts the problem for you.
I suggest do that first it is the cheapest option and then if that does not work ring who you bought it from whether that be a retailer or Bosch themselves.
Jun 18, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Hi can't find the instructin manual for my
I usually find some manuals on here after entering the model. You sure that is the right model? Look on the inside by the door. Good luck
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Mar 14, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch SRS4302GB Replacement Inlet hose - which type?
it should have and is delivered with the narrow bore high pressure hose
if your water flow rate is high more than 20 ltrs p min you could get away with a standard low preessure hose
you can download the instruction manual from the bosch web site or from the bsh home appliances web site
good luck
Mar 06, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
Feb 21, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
184 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
