Question about Kenmore 62882 Electric Dryer
Kenmore 80 Series dryer won't start.
When the start button is pushed, the dryer makes a humming noise which is normally accompanied by the dryer starting up. Now, it doesn't start. The noise stops when the button is released. Occasionally, the dryer will still start up. The sound made me think it was a belt problem. In opening up the back, I found several loose ball bearings at the base of the exhaust fan which made me think it may be more than the belt. It is possible the past owners ran these ball bearings through the dryer - I also found several bobby pins, a few nailes, etc.
Anyway, I read the detailed instructions given by SolutionGuy here:
http://www.fixya.com/support/t225746-broken_kenmore_dryer_80_series
and was so impressed I felt I needed to post my problem.
Electric Dryer:
Model 110
8867293
Type 180-00
Serial #MH4716973
Thanks!
  • noahgardner Apr 13, 2009
    Thanks! (especially for the no ball bearings on the roller info)
    Shortly after I posted I opened up more thoroughly and found that my dryer in fact does not have a belt at all, but a roller system. I cleaned thoroughly and found an old utility knife blade was jammed in at the edge of the drum. So far, it appears to have fixed the problem. I guess the moral of the story is that it's not a good idea to run tools through the dryer!
    It was an intermittent problem though, so I guess if it happens again I'll be looking for a new motor...
  • noahgardner Apr 14, 2009
    My mistake. There is a very narrow belt around the centre of the drum. There is also a groove at the back of the drum where I expected there might be a belt, but there is not. It appears the groove is for the roller(s) to fit into. However, I did not open the dryer completely or remove the drum. I haven't looked below it. Would it be right to say the rollers turn the drum while the belt just holds the drum in place?
    Genius:
  • 1,122 Answers
I see this all the time the dryer motor is simply to weak to kick in so it humms or sometime starts,a good test to do is flip the top up and push the start button and turn the drum at the same time and the motor should kick in,the dryer has no ball bearing it is on rollers,if you want you can check your local used appliance store and see if they have one or maybe ebay,your model number is inside the dryer door,so to sum it up it is the motor,let me know how you make out-mike
Posted on Apr 13, 2009
Testimonial: "Excellent knowledge. Thanks!"
  • MIKE major Apr 14, 2009
    YOU DON'T HAVE A LARGE BELT AROUND THE DRUM GOING TO THE MOTOR PULLY?THAT WOULD BE A FIRST FOR ME ON A KENMORE 80 SERIES,LET ME KNOW PLEASE-MIKE
    no the belt does not hold the drum,it turns it,the back rollers and the front panel lip hold the drum in place so it can turn,thanks for letting me know-mike
Kenmore 70 series electic dryer wont start make humming noise
your motor likely has a start-up capacitor to start the motor, it will be a cylindrical unit with 2 wires going to it, bring this with you to your local appliance repair depot and ask for a replacement with the same numbers on it, re-install as the old unit was uninstalled, this will likely the problem
Apr 15, 2012 | Kenmore Dryers
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
Kenmore 80 series dryer makes loud humming noise when it is drying clothes think it may be a belt that needs to be replaced
More likely is that your motor is going bad...that will make a very loud hum when it starts to go...
DryerRepair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 07, 2010 | Kenmore 65924 Electric Dryer
I have a Kenmore 80 Series dryer. When I push the start button it makes a noise but won't turn on or it turns on for a few seconds and then stops
Did you figure out what the problem was? I have the same problem with my Kenmore dryer.
Thanks
May 17, 2010 | Dryers
Dryer will not start upon pushing the start button.
the motor is more than likely bad but just to be safe check the blower wheel and make sure there is not anything in it then remove the belt and try to turn motor if the motor feels real tight then you need to replace the motor
Sep 18, 2009 | Kenmore 63942 Dryer
Kenmore 80 Series Gas Dryer won't run unless empty
MORE THAN LIKELY YOUR TENSION PULLEY IS SHOT WAS IT MAKING ANY SQUEEKING NOISES
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Kenmore 80 series dryer, won't turn on
Thanks for the question When you push the start button was thera hum if there is a hum when you push start you need a new motor THanks for the question The appliance doc
Jul 18, 2008 | Kenmore 63942 Dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore 62882 Electric Dryer Logo
1,596 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
