Question about Hotpoint NWXR473EV Dryer
CDT00 Hotpoint aquarius dryer The draw that contains the water is not filling up properly and instead waste water is flooding the floor........any ideas on how to cure this would be much appreciated.....thankyou
    Problem Solver:
  • 12 Answers
Pump at the back is most likely blocked or failing ... there are hoses running down the back make sure these are clear as a fisrt port of call .. also remove heat exchanger and make sure there is no build up of wet damp fluff blocking anything .. always remove from mains before attempting any repair
Posted on Sep 15, 2009
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Hiya wehave not long had ours and i dont no if im usuing it properly but al it is doing is filling up with water and doesnttrain so it flooding my kitchen. its a washer n dryer helpppp :)
hi you need a new level switch its a round switch with wires going into it with a rubber tube not expensive to repair and very easy to change let me know if you have any problems
Jan 17, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius CDT00 reverse action tumble dryer. Spins but no heat. Empted water and cleaned filter.
I have exactly the same problem, I am searching desperately for a solution. I really dont wont to buy a new one!
Jan 05, 2011 | Hotpoint Dryers
Hotpoint aquarius VDT60 fault F-15 keeps
F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
May 15, 2010 | Hotpoint Dryers
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wm63
hi in the powder tray is the conditioner tray there is usually a plastic part that the water runs up into so it can pass to the machine this plastic part gets blocked,pull it out and give it a good clean,if ther are two small plastic pipes make sure water goes up one side and down the other
Oct 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
190 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
