Question about Dual XDVD8170 Car DVD Player
RADIO WHEN PLAYED AFTER 20MINS IT GETS ALL DISTORTED WHERE YOU CANT UNDERSTAND. BUT EVERYTHING ELSE PLAYS FINE CD, DVDS TV NO DISTORTION AT ALL. EVERYTIME WHEN THE RADIO HEATS UP I GUESS IS WHEN IT HAPPENS. ANY HELP ON HOW TO FIX IT THX
    President:
  • 624 Answers
The only thing is replacing the PLL IC in the tuner circuit. It is failing when it gets hot.
Your best bet is a service center.
Posted on Jul 01, 2008
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
Color distortion when playing DVDs
If the player has other outputs try connecting the player to the tv using one of them, ie: use the A/V output instead of HDMI from the player. If the problem goes away there is something wrong with the input on the tv.
Mar 16, 2008 | Televison & Video
Denon DNS1000 distorted/fuzzy sound
Please visit www.denoindjforums for further help.
Jan 31, 2009 | Denon Dns1000 Table Top CD Player CD...
Peavey Bass Amp TKO115s
Start with a clean setting - zero cut and zero gain on the Eq. Play a song close to the amp, and then move away, playing the same notes. Do you still get the distortion? Change lower the input gain and repeat the test. Lower the output gain and repeat. Are any outboard distortion pedals in the mix, such as overdrive? Eliminate them. Run straight through from your axe to the amp. Check for any distortion settings. Set everything including reverb to zero. When the distortion disappears, this is your base setting.
Change only ONE parameter at a time. When the distortion comes back, you have found your problem.+
Dec 03, 2008 | Peavey EQ215FX Home Equalizer
Sony SLV-D300P Video Distortion
Have you tried pressing the progressive button on the front panel of the player?
Mar 27, 2008 | Sony SLV-D300P DVD Player/VCR
Screen colour is distorted
hi there
you may want to check the cable that connects your tv and player as this may be faulty already and start to recieve interference. try to clean the lens as well as this also give effect to the screen.
hope this helps.
Feb 12, 2008 | JVC TH-V70 System
Distortion
YOU SHOULD NOT PLAY CD,S IN SURROUND SOUND,SWITCH TO STEREO ONLY FOR CD,S AND OTHER MUSIC SOURCES.
HOPE THIS HELPS.
Dec 17, 2007 | Onkyo TX-SR500 Receiver
Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
Aug 16, 2006 | Sony DAV-SA30 System
Dual XDVD8170 Car DVD Player Logo
52 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
