FixYa.com
Tags:
Kenmore Elite 45986 Front Load Washer
Messy clothes
posted by wildlife on Sep 11, 2007
Does not use enough water to wash the soap out and the load has a smell.
Comment by wildlife, posted on Sep 17, 2007
I checked the hoses not the problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 13, 2007
Thanks for Trying (70)
premm
Rank:Guru Guru
Rating: 92%, 2259 votes
See that your inlet pipe is fully on, and that the passage of water is not restricted; could be some dirt has clogged the inlets. Check this out thoroughly, right into the machine point, that is by opening out the top to examine the pipes. Plug off the wall first.
Comment by premm, posted on Jun 13, 2008
Click on 'smell' above, tags. Will find several solutions there.
Rating Locked! (?) wildlife has rated this solution as Thanks for Trying
Solution #2
Not Rated (0)
pspman421
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
just manualy add more water until you find the real problem
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
Extraction cycle sounds like a...
Ok, found the rattle after... Answer This...
kenmore elite front load
f 11 code showed up this... Answer This...
tommy walkabout digital.!
how do i disable the... Answer This...
Front Load Washer Kenmore Elite
The clothes are still soaking... Answer This...
kenmore tumble action washing...
when the water empties out of... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
