Question about AEG Washing Machines
Tar like residue in washing machine
After doing a wash , sometimes there is a tar like residue left on the drum ?
    New Friend:
  • 4 Answers
It was the seal , I think the machine was not such great quality , thanks everyone for your help .
Regards Richard
Posted on Jan 09, 2014
vest6
  • 196 Answers
SOURCE: Lint or soap residue
Sounds more like a build-up of particles that may very well be in the water supply. There is something that you can try to get rid of these particles.
1. With the machine empty start it in normal eash mode and let it fill. Add 1/2 cup bleach to the water and let the machine run completely through the wash cycle. This will help remove any unseen stains or build-up.
2. When the machine drains and begins to refill on the next cycle, add 1/2-1 cup of white vinegar and again, let the machine finish its' cycle.
3. Run the machine through the wash cycle one more time to remove any vinegar that may have been left behind.
This is not a guaranteed method but I have had some success.
Posted on Jan 12, 2008
  • 1314 Answers
SOURCE: Tar-like substance appearing on clothes and washine machine
i havnt seen any flashes on this id look closley at what your putting in the washer as there is nothing in the unit its self as far as mfg that will cause this also try this 1. Open the washer door and remove any clothing or items from the washer.
2. Inspect the gray colored seal/bellow between the door opening and the basket
for stained areas. Pull back the seal/bellow to inspect areas under the seal/bellow.
3. If stained areas are found, wipe down these areas of the bellows using the following
procedure:
a) Mix a dilute solution of liquid chlorine bleach and water (3/4-cup bleach in
1 gallon of warm tap water).
b) Wipe the seal/bellow area with the dilute solution.
c) Let stand 5 minutes.
d) Wipe down area thoroughly with a dry cloth and let the washer interior air dry.
e) Please note:
- Do not use bleach at full strength for cleaning surfaces.
- The use of rubber gloves is recommended when cleaning for prolonged
periods.
4. To begin the clean out cycle, do the following:
a) Open the washer door and remove any clothing or items from the washer.
b) Be sure door is closed.
c) Open the dispenser drawer and remove the detergent divider from the main
wash detergent compartment. See the Use and Care Guide for instructions.
No additives will be added at this time. You will be required to add them at a
later step.
- For Whirlpool Duet, select the “Power” button.
- For Kenmore Elite HE products, move to the next step.
d) Select the “Normal” wash cycle.
e) Select the hottest wash water temperature available, (not all temperatures will
be available).
f) Select the highest spin speed available.
g) Select the additional or 2nd Rinse option (if available).
h) Press and hold the “Start” key for 2 seconds. The door will lock and filling will
begin. NOTE: The water will dispense for a moment, then the door will unlock
and re-lock and the cycle will continue.
i) Once the filling has begun again, open the dispenser drawer and immediately
add 1 cup liquid chlorine bleach to the main wash detergent compartment.
The liquid chlorine bleach should immediately flow through the dispenser.
NOTE: Do not add any detergent to this clean out cycle. Use of more than 1 cup of
bleach per month will cause product damage over time. Addition of bleach without immediately
starting the will cause damage to the product over time
5. Once the clean out cycle has begun, allow the cycle to completely run.
6. After the clean out cycle is complete, leave the door slightly open/cracked to allow
for better ventilation and prevention of future odor issues.
7. If you removed the detergent compartment divider, be sure to replace the divider
to the correct position.
NOTE: If necessary, the clean out cycle may be interrupted by pressing the “Pause/
Cancel” button. This will stop the cycle. A “Rinse and Spin” cycle must then be run to
thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage
to the unit and clothing added to the next cycle.
In addition to the clean out procedure, always do the following to prevent future odor
issues.
1. Use only High Efficiency (HE) detergent.
2. Leave the door slightly open after each cycle to allow for better ventilation and
drying of washer interior.
3. Repeat this clean out procedure only on a monthly basis, if necessary.
Posted on Mar 02, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
FitzOriginal
  • 842 Answers
SOURCE: Servis Washing machine clothes wet
I don't know the specific machine, but this is a fairly generic problem, so I hope the following helps: The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Posted on Feb 09, 2009
  • 245 Answers
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Posted on Jan 25, 2010
Our tub has some kind of black stuff all over it! It is like tar when we try to wipe it and it just smears. It sticks to the skin and does not wash off easily.
Try to remember the clothes washed prior to this showing up stuck to the drum. The source was something likely left in a pocket. Examine the clothes carefully for the same residue.
Try a small amount of liquid dish soak on a rag and see if it will dissolve into the soap. If not than it may be a silicone base material (black sealant) from something included in a prior wash. Unless there has been plumbing done recently at the house and if no other sink has shown similar characteristics you need to assume that it came in with the wash load.
I would load up the machine with rags and old work clothes set water level to full load set to heavy duty and hot water, Double up on the soap and let the machine do the work of cleaning. It may take a few cycles and a trace residue may always remain.
Nov 30, 2015 | Washing Machines
Were there recalls on any of ghese models
The problem of residual water in front load washers is an on going problem. Some companies had put in a small drain hose in their units to alleviate the problem. Your washer is actually built by Whirlpool. There is no available auxiliary drain for these models. These are the suggested solutions to alleviate for your particular machine.
1. Leave the door open after wash completed. This will help to evaporate the residual water. If in an area where the door cannot be left fully open then place a towel over the top of the door to keep it from closing and that will help by keeping the door open a small amount.
2. To alleviate odor, pour one cup of bleach in the drum... DO NOT PUT ANY CLOTHES IN THE MACHINE! Put the washer through a wash cycle... some models had a clean cycle if your has this then use this cycle. Once this has completed remember to do a white load following this procedure to assure that if there is any bleach residual then it wont cause problems with colors.
3. Dry the door seal after each use... this will eliminate mold from developing on the door seal. If you see mold then use a bathroom cleanser for mold removal to clean the seal... DO NOT USE A SOLUTION OF VINEGAR... THIS COULD DRY OUT THE SEAL CAUSING IT TO CRACK THUS REQUIRING REPLACEMENT.
FYI: The Maytag Company went bankrupt sometime ago, the name Maytag wash purchased by Whirlpool and appears on products to secure the business of faithful Maytag users...
Apr 19, 2014 | Maytag Neptune Washing Machines
My washing machine does not clean clothes properly and washing powder residue is left after wash on clothes I have Daewoo Dwd F1243
start a wash with a load and after he machine fills with water check to see if the drum rotates this is usually the problem if you get powder residue on wash with no drum action the powder does not disperse also check to see if the machine spins if it does check belt tension if not check belt tension and motor brushes
Mar 04, 2014 | Washing Machines
How can I remove tar from inside a washing machine's drum
Use mayonnaise, a sponge or a rag and some elbow grease.... My husband is a roofer and we always end up with some tar in the washer and dryer. So I just scrub it out with mayo. And do a soapy rinse afterwards in the washer, and if its in the dryer I throw a wet rag on a quick cycle to make sure there in no lingering mayo in the drum.
Oct 16, 2012 | LG Washing Machines
When I open the door of my wash machine it smells bad. What would cause this? Is there a lent trap with lent in it, causing this? If so were is the lent trap? Matag Neptune Washer.
Hi dear.I'm bit foreign to this model of Maytag.There for I do not know exactly where is the lint filter on it (Refer it's user manual)but I can help with the Bad Odour.If you are doing COLD WASH most of the time with your washer bad odour happens because of body oil & some other deposits(residue) left or sticks the drum after each wash.Cold wash cause that & if it gets worst mould problem going to start up.That's why you have to run the machine empty on Hottest Cotton wash cycle with some bleach every 6-8 weeks to get rid off residue.You'll see the difference.I hope that helps.Thanks.
Sep 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
My Hotpoint hvl211 has a lot of build up of 'residue' - basically gunk that gets stuck around the seal and between the seal and drum. It's really awkward to clean between washes but it I don't the residue...
The build up of residue as you refe to it, is due to doimn too many low temp washes.
you should do a boilok wash at least once a month, even if you do not put clothes in it, use the powder as normal with or with out clothes.
It is called a mintenance wash, and helps to stop buildup of grease and residue.
Feb 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Tar clothing
I would think you would need to presoak the tar stained clothes in a bucket of hot & Stong detergent water. If you use that stong a detergent in the washer you run the risk of damaging the seals. Either do that or use someone elses washer and drier. Then Run like He..!
Dec 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
MACHINE WILL NOT DRAIN COMPLETELY THEREFORE IT SMELLS
No washing machine drains completely , there is always residual water in the hoses and heater sump
If the machine smells do a couple of hot washes with no clothes in but add a good dose of soda crystals dissolved in hot water.
Pour this mix into the drum before you start the wash
Try going back to old fashioned soap powders for a few washes , these contain some bleach and soda which kill of the fats left inside your machine by the normal 40 & 60 degree washes
Jun 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Black, tar-like spots on some clothes after wash
Hi
Its probably coming from the outer drum of your machine. That's what holds the water. Your inner drum, what you see, is full of holes and allows the water to pass through in the drum and wash the clothes. that outer drum gets crud in it which then passes through the holes onto your clothes. the easiest way to get rid of it is to get a product called "affresh" from W mart or the big Hardware chains and follow the directions. Good Luck
Dec 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
182 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
