Question about Garden
Need to know how to change out starter string on 32cc sears weedwacker
pippall
  • 1486 Answers
SOURCE: what is the carburator adjustment proceedure for
Tighten the spring loaded screw.Then slacken off two and a half turns.ok.
Posted on Aug 09, 2009
digritz
  • 530 Answers
SOURCE: craftsman 32cc would not idle
If you are certain that you have correcting gaped the plug then the next step is to readjust the low end idle carburetor. If you look you should see two holes in the plastic cover that lead to the flow adjustment screws they may even be out in the open. If they are not labeled H and L (the L is the one you want), check your manual for the correct one. A good place to start is turning the screw all the way in then backing it out 1 1\2 turns. Then check it. If you still have problems do 1\4 turns out. After about one full turn from that you might want to consider taking the carburetor off and removing the float bowl or the bottom for a good cleaning. A sticking float could cause problems with your fuel flow.
Hope this helps.
Posted on Sep 03, 2009
rycgl
  • 1545 Answers
SOURCE: I need owners manual for 25cc, 17" Craftsman
Go to www.searspartsdirect.com and have your model number ready.
Posted on Jun 12, 2010
  • 100 Answers
SOURCE: 32cc Craftsman weedwacker dies at idle
could be blocked muffler
Posted on Aug 14, 2010
rycgl
  • 1545 Answers
SOURCE: craftsman weedwacker 32cc how to
It is threaded onto the end of the crankshaft (with regular R-Hand threads). I spray some PB Blaster solvent on it, let it soak. and the whack it on the inside "ears" with a flat blade chisel or a piece of small hard wood. I know...you have to lock up the engine so the crank won't move...and you can. Here is the entire process.
Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, ou will have to lock up the engine. Remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-2015 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the bottom of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25.
Posted on Jul 23, 2011
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Fuel line diagram for craftsman 32cc weedwacker weed eater
digrama for weed wacker 32cc modelo 368791156
Aug 23, 2012 | Garden
My 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Nov 15, 2011 | Garden
Was given a craftsman 32cc weedwacker. no manual. need to know what fuel it takes.
The website just says gas/oil (http://community.craftsman.com/Craftsman-Convertible-32cc-Gas-Line-Trimmer-reviews?tab=details). I'm not sure what that means. But on the Craftsman Community web page (http://community.craftsman.com/community) there is a link that says Feedback and Support. If you click that and fill out the form, someone should get back to you.
Hope this helps!
Jun 17, 2011 | Computers & Internet
Need to know the 2 cycle oil to gas ratio for a craftsman 32cc weedwacker trimmer
My Craftsman 31cc 2-Cycle Gas WeedWacker Model C216.51318 manual calls for a Fuel Mix (gas:oil) of 32:1
Jul 11, 2010 | Garden
WHERE CAN I FIND A REPLACEMENT HEAd CRAFTSMAN 32CC WEEDWACKER WEEDEATER
try contacting sears where it was bought from or they might be able to recommend the manufacturer
Sep 20, 2009 | Garden
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
