Question about Dryers
Dryer working to long to dry clothes
Dryer no longer dries clothes on timed dry setting, have to use automatic setting however the dryer won't shut off by itself we have to deep an eye on the clothes.it has started to take longer for the dryer to dry the clothes
  • 490 Answers
More than likely the belt needs to be replaced and the unit needs to be cleaned out (too much lint built up in the unit)
Posted on Apr 13, 2009
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
DRYER WILL NOT SHUT OFF ON AUTOMATIC SETTING
Most of the time when a dryer won't shut of in automatic, it is because the sensors inside the drum are bad and cannot sense when the clothes are dry. If your dryer works good on a timed dry then is probably the moisture sensors.
Oct 08, 2014 | Kenmore Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
Sometimes I have to run my dryer multiple times to get my clothes dried
Check your vent and vent hose for restrictions. Even a tiny air restriction will cause the thermostats to shut down quicker and take longer to dry the clothes. If you use softener wash out the filter well because the screen will clog up. Set the control to MORE DRY. Dry cottons on timed settings for maximum heat.
Sep 26, 2010 | Estate TEDS740JQ Electric Dryer
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Jul 14, 2010 | Samsung DV337 Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
Jun 17, 2010 | LG DLG7188 Gas Dryer
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Dryers Logo
154 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
