Question about 2wire (1000-400108-001) Router
Router i can't seem to hook up my router that i got from earthlink and get on the internet with my desk top. the modem is not recognize. no internet. always asking me to connect. then it tries to dial. help
    Genius:
  • 1,139 Answers
Hello debbie2, Ok areyou using DSL or Cable. Do this for me takea picture of the equipment you are talking about this will give me an idea of what to connect to what, because right now I am thinking this is how your system is connected. From DSL line to DSL Modem to 2Wire router to PC or From Coaxial cable to Cable modem to 2 wire router to PC That is what I am thinking. You are saying your problem is that the modem is not recogized by the router this could only be true if the modem is not connecting to the router at layer 2 of the OSI model (data link) I would ask you to reset your router to see if it connects to the modem and the pulls an address from the ISP. First I want you to log in to your router via the web page and find out what login and pass word you use to connect to your ISP. To reset your router press and hold the reset button until the lights on the front of the router blink. then log into your router again and restore the login and password. Once this is done check to see if you now have a connection between you and your ISP. Thank you, Shuttle83
Posted on Sep 12, 2007
SOURCE:
How do i hook up my desk top i plug it in to the router but get no internet
Make sure you internet modem is plugged into the proper input in the back, as well as making sure the computer is also plugged into the correct input.
The internet socket(where the modem goes) is normally separate from the rest of the ports.
Mar 19, 2011 | Belkin Basic Wireless Router
My WRT54GC router suddenly stop passing internet through it after 4 years of uninteruped service. But all the LED s are on as they should be. I can not get either wired (my desk top) or wireless (lap top)...
Has your modem been hard reset recently? if so, it may require that you bridge the modem out to work with the router- ESP. if you use Verizon DSL. If so, contact your ISP, and ask for assistance in bridging out the modem.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 03, 2010 | Linksys WRT54GC Compact Wireless-G...
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
When I hook up my Dell2350 router to my westell dsl modem i can not access internet with my desk top or my laptop. When i disconnect the router I can access internet through dsl for desktop with no...
You will need to check the settings of the router. You are able to go online when you connect the computer directly to the modem. Your internet service provider is DSL. You can try to reconfigure the router. Press the reset button on the router for 30 seconds. release it. unplug the power to the router. plug it back in. wait for 1 minute and try to reconfigure the router. Click Here for step by step set up
Nov 18, 2009 | Computers & Internet
I just got an earthlink modem and would like to
Connect your Earthlink Modem's RJ45 connector to your router's RJ45 WAN connector. The router should then provide wireless internet to other computers via their wireless cards.
Oct 28, 2009 | Computers & Internet
No DSL or Internet light
Does your mac book has a phone port? You can try that to setup a dial up connection an see if it will work.
May 20, 2008 | Zyxel Prestige 660R Router (91004397002)
I'm a little confused how to install this router I just bought. Model #wrt54g2. do I put the cd into my desk top which is already connected to the internet or do I install the cd in the new laptop I just...
Hi sheena -Is your desk top hooked up throgh the router? If not, plug your modem into the wan port on the router. The router should have come with a couple of short cables, most likely blue and yellow. Use the blue to connect your modem to your router. You can check the manual just to be sure. Use the ethernet cable that had been connecting your desk top to your modem, and plug into one of the wired ports on the router. I imagine you'll be using wireless for your laptop. Make sure that it is on. Put the cd in your desk top and run from there. Follow the directions. If you need more help just add a comment and I'll be glad to assist you further. If this solves your probleb PLEASE rate this as fixed. Remember. Need help? Just holler Sheena.
Jeff
May 04, 2008 | Computers & Internet
Earthlink
I hope you already have Easy set-up with Smart Wizard® installation CD with you. Connect router with LAN connection to your desktop and install software CD then it will ask you to provide DSL settings,for that better contact your ISP help desk they will give you in detail. netgear Easy set-up with Smart Wizard easy to use just you need ISP settings. good luck!
Dec 15, 2007 | NetGear RangeMax WPN824 Router
Router
Earthlink lists this as the number to call when you purchase someone else's router 1.800.327.8454. Hopefully if they are not the right people that can direct you to the correct people to call when you have earthlink's equipment.
I hope this helps.
2wire (1000-400108-001) Router Logo
113 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
