Question about Kitchen Ranges
Whirlpool RS675PXB or RS6755XB Built in Electric Stove Top and Oven. The Oven Cleaning latch is stuck so the oven door will not open. The Lever was forced open, the automatic oven latch is still locked. 1) Tried a Cleaning Cycle which worked.. but it did not unlock the oven after cool down. 2) Opened circuit Breaker to oven and the lock did not reset.
  • 1 more comment
  • RJEDad Apr 13, 2009
    Could not follow the thread and it took me to a solution about temprature control not a locked oven door
    The Oven Stove Unit is built in the Cabinets and the mounting screws are behind the oven door which I cannot open. I can access the latch if I remove the front glass of the oven. Is there anyway I can get the door open then that will allow me get to the back panel. I should have put that in my first question. Sorry about that.
  • RJEDad Apr 14, 2009
    No error message that I see even after running through another complete cleaning cycle for 2 hrs
  • 190 Answers
Dear customer,
                 You may have to unplug the oven/appliance from the electrical power, disable the locking device and not use the self clean cycle anymore or until another problem developes which requires a service tech. At that time have the lock replaced.
Or replace the locking device yourself. But first check and insure the lever is traveling far enough to unlock the device, the lever is not bent, etc. May be able to disassemble front panel and manually release the locking device and/or disconnect the quick disconnect wires to the device, etc.
The above suggestions are not the professional methods granted. But if you do not want to fix the device or replace it, bypassing it is possible. All you will loose is the self cleaning operation, until a fix is done correctly.
thank you..
Posted on Apr 14, 2009
  • 530 Answers
Friend stanby for a while i'll sent you how
  • Joseph Baculan
    Joseph Baculan Apr 14, 2009
    set the selfclean and after you hear it lock down then cancel the operation and wait to give it time to unlock ,,, may take up to 10 minutes ,,, if it dont unlock you will need to get into the back of it and run the door latch back by hand
    Take the back cover off the the stove. UNPLUG THE STOVE
    On the left rear facing the back of the range youll see that the timer motor had stopped.may sure you unplug the input(230 volt power) leading to the stove, then unpluggand insulate the wiring to the timer motor and the microswitch on top of it ( 4 wires). Then take the long steel wire off of it and unlatch the oven door.
    this probably had something to do with the timer motor on the self cleaning cycle and that it was stuck
    Do NOT use the self cleaning function unless you fix the timer motor. Replace it or clean it.
    Hope this helps
  • Joseph Baculan
    Oven locks for 2 reasons:
    1. Cleaning cycle which gets really really hot for ~2hr
    2. Parent protection.
    If you press and hold Cancel for 15-30Sec, it should unlock it. If not, pull the plug ;-)
    If it still does not unlock, the lock mechanism may be stuck. Power pushes a pin out, a spring pulls it back in, If it sot too hot, it my be stuck. Try hitting it with a shoe in the top middle, under the handle. If it won't unlock, you may hafe to take the top off to release it. Call Whirlpool cust support at 1-800-253-1301 for assistance.
    Genius:
  • 1,847 Answers
Are you getting any error message ?
First, disconnect the power to the range (either unplug it or turn the power off at the circuit breaker). Pull the range out and remove the back panel.
Your range has a door latch in the front and a door latch solenoid (with latch switches) in the back. There is a thin metal rod that connects the two.
When the board sends a signal to the solenoid to lock the door, the solenoid turns the rod which locks the latch.
With the back panel off, you should now see both the solenoid and the rod.
You can now manually release the latch by turning the rod (probably clockwise). You should now be able to open the door.
Put everything back the way it was and with the door open turn the power back on. Press and hold any key on the board for one minute. This should release the error code (if you are getting one). Press CANCEL and give it a few minutes to see if the code comes back. If it doesn't, you can start baking If it does come back, you'll need to test the latch switches and the solenoid.
Let me know the. Kindly rate the answer ...
Thanks
Kevin
Posted on Apr 13, 2009
    Sergeant:
  • 431 Answers
Kitchen.manualsonline.com/ex/thread/view/idThread/1040147
It's frozen on E1 -F5- and oven won't come on. the top of stove is ok
Your code refers to a door latch problem that is stopping the oven circuit from completing.
It could be a bad door latch switch.(most likely).
OR
A bad relay on the control board to the door switch.
Mar 30, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Door stuck after cleaning cycle? Can hear latch release but door will not open. Power still good. Oven still works, just can't open door,
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 16, 2010 | Whirlpool GMC275PD Electric Double Oven
I am in the process of cleaning my Whirlpool self cleaning oven and it seems like there should be about 2 hours left on the timer and when I came out to the kitchen the timer was off and the door is still...
most likely the safety latch got stuck from the super heat of the oven while cleaning. try tapping the latch with a screwdriver and hammer, spray a bit of wd-40 on it wont hurt. i believe the self cleaning on ovens is crazy, as the heat damages things, including the finish of the unit.
Jun 22, 2009 | Whirlpool RBS275PD Electric Single Oven
Self cleaning oven door lock is stuck and buzzing
you can still use the oven i would gt someone out as soon as you can to get the lock released but yes you can still use the oven
Feb 04, 2009 | Frigidaire GLEF396 Electric Kitchen Range
OVEN DOOR WON'T OPEN
as a firefighter i know this lift open the top of your stove and there are 4 screws on a metal plate take those off and your latch release will be under there try that e mail back at firefighter00@fctvplus.net
Dec 07, 2008 | Hotpoint RB787 Electric Kitchen Range
Maytag stove will not open after cleaning
is the oven completly cooled down? the latch is hat sentisive the oven must be cool before the latch will open this can be from 15 min to 2 hours after the clean cycle is complete
Aug 25, 2008 | Maytag MEW6630D Electric Double Oven
OVEN NOT WORKING
You have probably damaged the latch and other sensors around the door. Make sure that the is not bent or out of alignment.
more asst.
eboukater@gmail.com
Jul 01, 2008 | Jenn-Air JJW8530C Expressions Collection...
Kitchen Ranges Logo
179 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
